Does anyone know where I can find a new oil cooler for a 1983 6.9l I have found new o ring kits but I would like to install a brand new cooler as well.
if it is an 83 you are going to want to buy a later model used one, the early oring setup is prone to leaking. So a complete setup with both headers would be good. I would have one but a customer never returned the exchange core.
I just recently put new o-rings in a 86 6.9. We could only get them from the stealership and one diesel shop. The diesel shop said that the early models had a four o-ring set-up. From what I understand, the early models are the only different ones. 6.9 and 7.3 (up to 94 1/2) take the same o-rings. The front heads on the oil coolers are different from the E series and the F series. Also, the diesel shop o-rings were FORD items anyway, so it would be cheaper just to get them from the stealership.
Your welcome.I like to help anytime I can.I only knew this because we purchased an 86 E350 25 passenger van at church. The motor was gone. Only got 76,000 on the od. We bought a motor out of an 86 F250. Needless to say, we learned the differences. The HARD way!
