ScanGauge II denier
#61
#62
#63
If you guys do have Green coolant in there you should use some stuff called Restore and restore Plus IIRC
Ford recomends stuff Called VC-9 it works Great for Cleaning out any rust and stuff
IIRC the Restore Plus is used to clean out Silicate Slim type stuff what is probably more what you want if the green has slimed the system
Iv done mine 3 times now and only used the Ford VC-9 but i didnt have any slim
The best way I found to really clean the system good is to Pull the thermostat and Run the Cleaner for 1 1/2 Hours parked in the driveway with a Brick on the accelerater pedal at 1100 rpm it got upto 150-160*f and then only took a couple flushes after that to Flush CLEAR Worked Great
I also tried it without Pulling the thermostat and Could NOT Ever get it to flush Clear even 12 water flushes later still wasnt clear
Dave I will throw alittle Caution your Way but some folks have Clogged the Oil Cooler with flushing especialy when the Oil Cooler is like yours that being its been run in the truck for awhile and the Deltas are Borderline
But with Dieselvol his oil cooler being so new if it did clog the oil cooler a reverse flush would clear it up
#66
Thanks, Benny... I've still got that oil cooler I bought for my red truck, so I've got one ready to go if I do plug it. I've always used the vc-9 in my flushes. I'll check out the restore for the slime too. And I'll be pulling the tstat for sure. I'm replacing the tstat on my personal truck cause I've never seen coolant go over 180 unless pulling a 7000# trailer up an 8% grade.
#68
If I've taken in all I've read and all you've said here correctly (highly doubtful), it appears my first step is to do a reverse flush of the oil cooler. Does the tech file show that a Fumoto valve can be put in without removing the starter, or does it say to remove the starter, put the valve in, then never have to remove the starter again? Lots more questions to follow, I'm sure...
#70
Something is telling me your Oil Cooler is OK and the problem is something eles
How many miles on the New Oil Cooler?????
Was the ECT & EOT Spread good Right after the work?????????
#71
It has around 2.5 to 3k at most. It would run around 11-12 and some brief 13 the day I got it back. I was pretty disappointed. It did pretty much the same prior to the change. We changed it just because it was already apart, not because it was getting progressively worse.
#72
Makes Me wonder if the mechanic even changed it at All the oil cooler that is
what Coolant was in it
#73
It was the Ford Gold before. If he didn't change it, that would be a MAJOR fraud, as he definitely did the studs. I can't imagine not changing out the cooler with the part sitting there (I bought it and had it delivered to him) and the engine already apart. He also described the way the other one was put in wrong. I'd have to have really misjudged him.
#74
well he probably did change that Oil Cooler
What color coolant is in Now????
Iv seen guys put 3 & 4 Oil Cooolers in Bad Mouthing Ford the whole 9 Yards come to find out they never flushed the cooling system out
For now Maybe we should look at irt like the Oil Cooler is New it got Flushed cooling system (How well????)
SO that leaves a Coolant flow issue (Water Pump or Cavitated Front Cover)
A sensor Issue (However they sound OK)
a wireing to sensor isue
the water Pump has plastic fins so they can break
If coolant wasnt kept at 50/50 mix the front cover can cavitate and wont Flow right
#75
