I'm looking to pick up some gauges for Christmas this year. I know I should have done been looking into them a long time ago, just never think about it.
Ispro EV2's are the way to go if you ask me, but order them from Clay at RiffRaff diesel.
He knows the owner of isspro as well and can get you what you want easier than others being that he's within a short distance of the factory.
- Pyro 0-1600ºF
- Boost 40psi
- Trans 100ºF-280ºF
- Fuel Pressure 0-100psi (Optional)
- R72022 Wiring harness/dimmer
- RDP Drill and Tap Set
The EV2 are a little more expensive that the older EV in the link you posted, but have much great technology and reliability in the long run. Let me know if you have any questions.
- Pyro 0-1600ºF
- Boost 40psi
- Trans 100ºF-280ºF
Added to my wish list. Thanks. Do yall carry a 4 pod pillar?
- Pyro 0-1600ºF
- Boost 40psi
- Trans 100ºF-280ºF
Clay, my engineering mind wants to know if I can run a temp gauge with a switch so i can see actual engine temperature, transmission temperature, and even drive axle temperature from the same gauge. just have 3 probes and a rotary switch to set which one is being read at that time.
