Tranny ???
Old Dec 2, 2012 | 04:57 PM
T. Driver's Avatar
T. Driver
Cool Tranny ???
I have a 96 F-250 power stroke 2WD with a dead automatic transmission, I've found a 98 model with a good low mileage transmission are the two compatible ??
Old Dec 2, 2012 | 05:22 PM
jroehl's Avatar
jroehl
When you say a '98 model, what do you mean? There was no '98 F250 with a PowerStroke diesel.
Your '96 likely has an E4OD (some fleet vehicles still got the old C6). What you need is an E4OD from behind a diesel, as the diesel had its own bellhousing bolt pattern, preferably a '95-'97 F250HD or F350.
Jason
Old Dec 2, 2012 | 05:42 PM
tjc transport's Avatar
tjc transport
i ain't rite
actually there were Jason. they were left over 97's tagged as 98's in Canada. not sure on the F-250 part though, but i bought 4 98 F-350 diesels and 2 gassers at auction for the other company
Old Dec 3, 2012 | 05:04 AM
T. Driver's Avatar
T. Driver
The 98 model refered to is out of a box van. I've not seen it. A friend of a friend found this and says it shows 102K miles. It is a 7.3 powerstroke Diesel. As far as the E40D....I'm not sure.
Thanks for your response !
Old Dec 3, 2012 | 06:12 AM
jroehl's Avatar
jroehl
If you have overdrive, it's an E4OD. The gear indicator will read P R N (D) 2 1, plus you'll have a button on the end of the lever. If it's a C6, there won't be a button on the end of the lever, and the indicator will read P R N D 2 1.
Jason
Old Dec 3, 2012 | 06:36 AM
T. Driver's Avatar
T. Driver
Tranny trouble !
I do have an OD W/button etc. and so does the 98. Sooooo...I assume, the 98 is compatible ? Right ?
Thanks for your help !
Old Dec 3, 2012 | 05:08 PM
jroehl's Avatar
jroehl
It should be. I'd double-check the tranny pan--if it's the same (20 bolts), then you should be good to go. I'm not sure when they switched from the E4OD to the 4R100. The 4R100 would fit, I'm sure, but may not be compatible with your computer. Those more knowledgeable than I would have to chime in.
Jason
Tuckering
Mar 9, 2015 08:52 PM
glovemeister
Ford Truck Parts for Sale
Jul 9, 2014 02:05 AM
Power of 8
Mar 26, 2013 07:37 PM
401477534
Apr 11, 2011 11:06 PM
Hillclimber
Aug 30, 2004 09:33 AM
