Been away for a while.
Old Dec 1, 2012 | 01:39 PM
22fordguy's Avatar
22fordguy
So do to tech support not wanting to reply to emails I have had to start over with a new user name (formerly 17fordguy) My 07 F250 Started acting up a couple of days ago not shure if its due to the low temperatures we have been having or a mechanical promblem. Mainly at highway speed if I hit the gas it Downshifts and just boggs like a lack of fuel. no codes according to SG. Currently in the procces of doing all filters and fluids to include fuel oil trans and differentials. Also pulled EGR valve last night and found what appered to be a small amount of oil in it. Any ideas? Also when i say Low temps I mean -34 currently.
Old Dec 1, 2012 | 02:28 PM
BLADE35's Avatar
BLADE35
I think tech support been busy as the site has Crashed a few times
post
ICP
ICPV
IPR%
Volts
FICM MP
FICM LP
FICM VP
BARO
MAP
EBP
Old Dec 1, 2012 | 02:47 PM
22fordguy's Avatar
22fordguy
As soon as I get the truck back up and running I will. fond a trans fluid leak on the rubber hose from the cooler to the filter on the passenger side. Also is it normal to have two inline filters on the cooler lines.
Old Dec 1, 2012 | 03:29 PM
BLADE35's Avatar
BLADE35
POST them if you want any Help to get the Truck to Start!!!!!
All at KOEO (Key On Engine Off)
and again during crank when you take the crank Numbers Give the ScanGauge time to Update4-6 seconds or till you see it change
Set Update Rate to Fast
Use the Gauge to Figure whats Wrong Bud
Prgram SGII
FLP 07E02209EF 0462450906CF 3010 006401000000 FICM Logic Power (Volts). Should be 12
Key On = 12.0
Low Idle = 13.5
High Idle = 13.5
Operating Range = 10.5
15.5
AP%
Accelerator Pedal Position (%) TXD: 07E02209D4 RXF: 0462050906D4 RXD: 3008 MTH: 000100020000 NAM: AP%
BAT
Battery Voltage (Volts) TXD: 07E0221172 RXF: 046205110672 RXD: 3008 MTH: 000100100000 NAM: BAT
BST
Boost (Untested) TXD: 686AF1010B RXF: 0441850B0000 RXD: 2808 MTH: 00910064FF88 NAM: BST
CVI
VREF (My notes indicate that this is the Calibration VTXD: 07E0221155 RXF: 046205110655 RXD: 3010 MTH: 000133330000 NAM: CVI
EBP
Exhaust Back Pressure TXD: 07E0221445 RXF: 046285140645 RXD: 3010 MTH: 001D00500000 NAM: EBP
EGR EGR
Duty Cycle (Percent) TXD: 07E022166E RXF: 04620516066E RXD: 3010 MTH: 006440000000 NAM: EGR
EGV
EGR Valve Position (Volts 0-5) TXD: 07E022167E RXF: 04620516067E RXD: 3010 MTH: 000133330000 NAM: EGV
EOT
Engine Oil Temp. TXD: 07E0221310 RXF: 046245130610 RXD: 3010 MTH: 00090005F05F ( UNAM: EOT
ERT
Engine Run Time TXD: 07DF011F RXF: 0441051F RXD: 2810 MTH: 0001003C0000 NAM: ERT (Mi
ETP
EGR Throttle Position Control Signal TXD: 07E022096C RXF: 04620509066C RXD: 3010 MTH: 00647FFF0000 NAM: ETP
EVD
EGR Valve Position Desired (%) TXD: 07E02209D2 RXF: 0462050906D2 RXD: 3010 MTH: 00647FFF0000 NAM: EVD
EVM
EGR Valve Position Measured (%) TXD: 07E02209FE RXF: 0462050906FE RXD: 3010 MTH: 00647FFF0000 NAM: EVM
EVP
EGR Valve Position (mm) TXD: 07E022096A RXF: 04620509066A RXD: 3010 MTH: 000100010000 NAM: EVP
FI1
Fuel Injector #1 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3001 MTH: 000100010000 NAM: FI1
FI2
Fuel Injector #2 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3101 MTH: 000100010000 NAM: FI2
FI3
Fuel Injector #3 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3201 MTH: 000100010000 NAM: FI3
FI4
Fuel Injector #4 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3301 MTH: 000100010000 NAM: FI4
FI5
Fuel Injector #5 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3401 MTH: 000100010000 NAM: FI5
FI6
Fuel Injector #6 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3501 MTH: 000100010000 NAM: FI6
FI7
Fuel Injector #7 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3601 MTH: 000100010000 NAM: FI7
FI8
Fuel Injector #8 Commanded on (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3701 MTH: 000100010000 NAM: FI8
FL
Fuel Level TXD: 007E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 NAM: FL
FLP
FICM Logic Power (Volts) (Should be 12 volts) TXD: 07E02209CF RXF: 0462450906CF RXD: 3010 MTH: 0064010000000 NAM: FLP
FMP
FICM Main Power (Volts) (Should be 47-48) TXD: 07E02209D0 RXF: 0462450906D0 RXD: 3010 MTH: 0064010000000 NAM: FMP
FPW
Fuel Injector Pulse Width (microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW
FSS
Fan Speed Sensor (RPM) TXD: 07E022099F RXF: 04620509069F RXD: 3010 MTH: 000100040000 NAM: FSS
FVP
FICM Vehicle Power (Volts) (Should be 12 Volts) TXD: 07E02209CE RXF: 0462450906CE RXD: 3010 MTH: 0064010000000 NAM: FVP
HPR
Horse Power TXD: 00 RXF: 400080000000 RXD: 0000 MTH: 000A00240000 NAM: HPR
IA2
Intake Air Temperature 2 (Fahrenheit) TXD: 07E02216A8 RXF: 0462051606A8 RXD: 3010 MTH: 000100010000 NAM: IA2
ICP
Inj. Control Press. TXD: 07E0221446 RXF: 046205140646 RXD: 3010 MTH: 003900640000 NAM: ICP
IPR %
IPR Duty Cycle TXD: 07E0221434 RXF: 046285140634 RXD: 3008 MTH: 0DCA03E8000A NAM: IPR %
ITM
Injector Timing Before Top Dead Center (Degrees) TXD: 07E02209CC RXF: 0462850906CC RXD: 3010 MTH: 000A00400000 NAM: ITM
MFD
Mass Fuel Desired TXD: 07E0221412 RXF: 046245140612 RXD: 3010 MTH: 006400100000 NAM: MFD
PSI
Manifold Absolute Pressure TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI
PSI
Boost TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI
SYC
Crankshaft Position Sensor TXD: 07E02209CD RXF: 0462050906CD RXD: 3000 MTH: 000100010000 NAM: SYC
SYC
Camshaft & Crankshaft in sync (1 = in sync) (AlternTXD: 07E02209CD RXF: 0462050906CD RXD: 3001 MTH: 000100010000 NAM: SYC
TFT
Trans. Fluid Temp. TXD: 07E1221674 RXF: 046205160674 RXD: 3010 MTH:000100080000 NAM: TFT
TP1
Throttle Position 1 (Volts) TXD: 07E0220917 RXF: 046245090617 RXD: 3010 MTH: 0064040000000 NAM: TP1
TP2
Throttle Position 2 (Volts) TXD: 07E0220918 RXF: 046245090618 RXD: 3010 MTH: 0064040000000 NAM: TP2
TPA Throttle Position Actual (Degrees) TXD: 07E022093C RXF: 04624509063C RXD: 3010 MTH: 0064020000000 NAM: TPA
Find them Here^^^^^^^^^^^^
Old Dec 1, 2012 | 03:46 PM
BLADE35's Avatar
BLADE35
Reread it does run Good but still use the SGII
So Post those numbers at KOEO Low Idel and High Idel (2500rpm)
changed fuel filters recently
Old Dec 1, 2012 | 09:07 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
You need a shorter list there Benny! LOL. Since your standard info request are these gauges, I'll throw one together for your convenience.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
MAP and Volts should already be in the gauge.
Old Dec 1, 2012 | 09:21 PM
cheezit's Avatar
cheezit
fuel related is what it sounds like at -34* i would think maybe a gelling issue. try anti-gel and a 0%bio fuel. may also be a weak lift pump. check both fuel pressure and inlet suction to isolate
Old Dec 1, 2012 | 10:25 PM
BLADE35's Avatar
BLADE35
Thanks Sean I was Busy
Im going to copy your List Been needing a short list for a few
Old Dec 2, 2012 | 01:22 AM
22fordguy's Avatar
22fordguy
Ok guys sorry it took so long to get back with you about the truck After doing all the filters truck is doing alot better noticed the frame mount fuel filter had a green goo in it not shure what it was from. I always run a bottle of the power diesel with every tank. Also on another note What is normal operating temp on coolant oil and trans.
fbrtransbear
Jun 15, 2012 10:32 AM
tirnaog
Jul 2, 2008 06:32 AM
MAKO314
North Carolina Chapter
109
Aug 17, 2006 10:58 PM
chrono4
Dec 21, 2004 09:26 PM
