generators?
Old Dec 1, 2012 | 11:41 AM
Greg5OH's Avatar
Greg5OH
generators?
Has anyone heard/done/has a generator powered by the engine in the truck? Or better to just get a portable generator for the bed?
Looking to run grinder, and a 220 v welder (no more than 40 amp draw).
Old Dec 1, 2012 | 12:01 PM
mozzles's Avatar
mozzles
Not sure about running it off your starting battery if that's what you mean, but a lot of people for "truck camping" will get a deep cycle marine battery and wire it to the starting battery, with a battery isolator in between so that it doesn't drain your starting battery/batteries.
Old Dec 1, 2012 | 12:13 PM
Greg5OH's Avatar
Greg5OH
thinking a welder would drain a battery pretty quick times. Wouldnt i need something that is constantly generating power at 220 volts (for the welder-it would draw 40 amps max, its mainly for hobby welding/minor fixes)
Old Dec 1, 2012 | 12:35 PM
Greg5OH's Avatar
Greg5OH
wow 40 amps at 220 v is 8800 watts. guess a relatively small generator wouldnt even keep up with that!
Old Dec 1, 2012 | 12:41 PM
turtlemann14's Avatar
turtlemann14
there are pto gensets available
other than that you could convert a couple of alternators over(but it would take more work)
Old Dec 1, 2012 | 02:29 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
If you're talking about a belt driven type generator like the air compressor units that are available, I have never heard of one. There would not be enough room in the engine compartment for the size field and armature it would take to generate 8800 watts of power. If your intent is 50% duty cycle or more, and you plan to do a lot of welding with, you would be far better off with a gas (or diesel) welder that also generates 110 power for your grinder.
Old Dec 1, 2012 | 02:48 PM
Greg5OH's Avatar
Greg5OH
ya looked into some gen/welders they seem the way to go. Keep that one mounted on the truck and my 220 at home.
would be cool to bottom mount it under the bed somehow!
Old Dec 1, 2012 | 03:58 PM
tjc transport's Avatar
tjc transport
i ain't rite
find a used lincoln or miller gas powered stick welder. they also have 110 volt plugs on them, and most have 220 plugs too.
i paid $300 for my miller bluestar 3 years ago. it was basically a new machine. over it's 20 year life, it was used as a backup generator 4 times, and welding 2 times. all it did was sit in the bed of a pickup.
i actually paid $300 for the truck and welder, and scrapped the truck after taking the welder out of it.
Old Dec 1, 2012 | 04:02 PM
Greg5OH's Avatar
Greg5OH
^now thats a hell of a deal!
Old Dec 1, 2012 | 04:48 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Theres no way you will run a 220 welder off your truck lol. You couldnt even run a grinder through a power inverter, and if so, barely. You need a stand alone generator with a 220 plug or a gas/diesel powered welder to put in the bed. For what its worth, dont waste your money on a lincoln welder, go with Miller. Every experience ive had with lincoln machines has hailed in comparison with miller machines
Old Dec 1, 2012 | 11:47 PM
joshofalltrades's Avatar
joshofalltrades
wanna bet? i run an air compressor off mine all the time, draws about 1200w, and thats powered by a single aux battery, size 4d. i have over half an hour of runtime before the inverter even starts to complain about low voltage
now running the welder, thats either a PTO driven generator or a generator with its own engine
Old Dec 2, 2012 | 07:05 AM
Ford4Life7.3
I was talking about one of the small inverters you plug into the cig lighter. Where do you keep the battery? Deep cycle? Interested in your setup there.
Old Dec 2, 2012 | 07:36 AM
tjc transport
i ain't rite
on the 01 F-450 diesel service truck at the new job, there is a 4000 watt power inverter mounted in the driver side front compartment. fire the truck up, flip the high idle switch, turn the inverter on, and plug in what you need to use.
i would still use a gas stick welder though for any welding.
Old Dec 2, 2012 | 08:22 AM
joshofalltrades
ok yeah, the little baby inverters you were thinking about would be hopeless, but they're perfect for charging a laptop or a couple power tool batteries.
as for my system, here https://www.ford-trucks.com/forums/1...le-advice.html thats my thread from when i set it up. as you'll notice there, i'm in a van, and found a space outboard of the left frame rail where i could fit the battery - actually i could fit two of them, but would have to build another support and buy another battery if i wanted to
Old Dec 2, 2012 | 05:15 PM
Ford4Life7.3
Pretty cool Josh, thanks for the info on that.
