You tell me...
#31
"It really pisses me off that they can't shift the two pieces around the rear window a couple inches over in their die-cutting machine and make a factory cut for the 51-52's. I fully expect there will be a slip of the knife doing that."
The cut will actually be more like 6 or 8" out of each side. You will be left with very thin strips above and below the window.
For the dome light take the lense out and measure it to the center and start with an X and trim it out a little at time. Atleast that is what I did.
#33
#35
I stand corrected my wife reminded me it was actually about 3 1/2 to 4" inches on each side. I was including the strip part that I mentioned before.
I guess the window is maybe 8" wider or somewhere in that neighborhood.
#36
#38
i remember the rear window being the hardest part to get looking right. i trimmed more off above the window than Carolina 52's picture, but i think his looks better than mine.
mine also has the small gap between panels just below the window on the drivers side as pictured, i don't know why it's there.
#39
Holy crap, is there supposed to be a piece of metal over the rear window seal?! I sure don't have one. I was wondering what would "finish" the edges around the window.
Those "hand-hold" gaps in the panel below window are a puzzle.
Great pics, thanks! I won't get to that area for a couple of days.
#40
#41
#42
#44
If you're not replacing the rubber at the same time as the headliner trim installation, my tip would be to clean the rubber around the glass with lacquer thinner on a rag before installing the trim. It'll give the rubber a new look without the slime of tire dressing messing up the new kit.
#45
