65 Trans parts needed
Old Nov 30, 2012 | 01:24 PM
Prettybird81's Avatar
Prettybird81
Any idea where I can find parts for a 65 BW Trans? I need cluster gear & first/reverse slider. I have no idea where to look. Thanks for any leads!
Old Nov 30, 2012 | 01:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Your question is very vague. What series of truck? 3 or 4 speed? 2WD or 4WD?
If it's an F100 w/a 3 speed, the only BW trans offered was the T-85N Overdrive with non syncro 1st gear.
Old Nov 30, 2012 | 01:59 PM
Prettybird81
Trans is a Borg Warner with case number T85 N and tail housing is R11-1W Need cluster gear and first/reverse slider. Borg Warner part numbers are T85N-8 and T85C-12D and I believe the original Ford part numbers are C5TZ-7100A and C5TZ-7113F
It's a 3 speed with the slip first gear. I can't remember if it has 4WD... doubt it... it's been off the road a long time. Any help or direction would be greatly appreciated! If more info is needed i'll try to figure it out.
Old Nov 30, 2012 | 02:47 PM
NumberDummy
Borg Warner part numbers are T85N-8 and T85C-12D and I believe the original Ford part numbers are C5TZ-7100-A and C5TZ-7113-F
Borg Warner T-85N 3 Speed Overdrive, installed in 1965/71 F100's. Not available with 4WD. I had the same trans in my '65 F100 352 8' Styleside.
1964/72 Ford Truck Parts Catalog / Text, Section 70.2, Parts List #70.2C / Catalog available on a CD from hipoparts.com / Has cross reference: Manufacturer to Ford/Ford to Manufacturer part numbers.
Sorry, no Ford Dealer or obsolete parts vendor has either one.
Old Nov 30, 2012 | 02:54 PM
Prettybird81
Well that makes it hard to fix... bummer. What are folks doing with them... I don't have to scrap it and get a new trans do I?
Old Nov 30, 2012 | 03:00 PM
NumberDummy
I have a pal who might have the parts, might be used, might be NOS, might have a complete used trans.
But I cannot go there and find out until after Xmas.
Old Nov 30, 2012 | 03:07 PM
Prettybird81
I have a pal who might have the parts, might be used, might be NOS, might have a complete trans.
But I cannot go there and find out until after xmas.
I'll let you know if I find something... but if/when you go if you'd check i'd be appreciative. I'm in Michigan... i'll keep looking in the meantime. Thanks for your help!
beckman
Dec 21, 2012 10:05 AM
es2rider
May 4, 2011 01:40 PM
jef
Mar 9, 2007 11:13 AM
DannyP
Jul 11, 2006 03:00 AM
