Sponsored by: Real Truck
Electrical drainage?
Old Nov 29, 2012 | 08:19 PM
brickin70's Avatar
brickin70
I have a 99 F-250, 7.3 4x4. For the last few months I have experienced the batteries being dead after setting for 4-5 days. Any ideas on where to start looking?
Old Nov 29, 2012 | 09:41 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello brickin70 and welcome to FTE.
I would start by having the batteries load tested. A bad battery will "die" after sitting a few days, especially in colder weather. One bad battery will drag down the other if you have two (which you do).
If the batteries check out good, then you need to look at your charging system next. Are the batteries getting a full charge from your alternator, or alternators if you have 2. Are your cables in good shape? Are the battery terminals clean and free of rust an corrosion?
If it all checks out OK then you need to find a clamp-on amp meter. Put it on your positive lead and measure the current draw with the engine off. If there is more than about 250 milliamps, you have some sort of parasitic load. Start pulling the fuses, one at a time, until you see the load drop. Find out hat that fuse does and you will have a good start at solving the issue.
Old Nov 30, 2012 | 06:58 AM
SC_Hoaty's Avatar
SC_Hoaty
+1 on what redford said.
Lots of auto parts stores will load test the batteries. I would hook 'em to a bench charger first, so they are fully charged when you go to the store. You may want to pull the ground lead off each battery while charging to ensure all the juice goes to the batteries.
kevinb63
2009 - 2014 F150
Apr 29, 2017 08:50 PM
nick c
Sep 26, 2016 05:22 PM
RedfireSVT
Sep 16, 2016 11:52 AM
Tanner2255
13
Jan 21, 2014 10:42 AM
jimmy don
Jul 1, 2010 05:51 PM
