Oil & Lubrication
Oil for 460?
Old May 22, 2003 | 10:40 PM
carpe_diem's Avatar
carpe_diem
Oil for 460?
I have a '95 460cid truck with relatively low miles (less than 50K), any suggestions on what the best dino oil to use? Which weight?
I don't drive it that much, maybe a few times per week at most.
Old May 23, 2003 | 10:06 AM
mikemc's Avatar
mikemc
Oil for 460?
Your truck's owners manual probably recommends 5w30 or 10w30. It may also specify oil weight on the oil filler cap. I would use a good dino 10w30 like Castrol GTX or Chevron Supreme. If you regularly experience climates below freezing, 5w30 may be a better choice.
Old May 23, 2003 | 11:16 AM
TallPaul's Avatar
TallPaul
Oil for 460?
I have a 1990 motorhome with a 460 and 63000 miles. I run exclusively Valvoline Durablend (part synthetic) 5W30 and one quart of Rislone every oil change. In fact I run this combo in all my vehicles.
EDIT: WHAT THE? I thought I was responding to the "Oil for 460?" post by Carpe Deim and it ended up here. Must have hit the wrong key. Oh well. Moderator, please move this over there or delete this if you get a chance. Thanks.
Threads merged
Old May 23, 2003 | 07:07 PM
02PSD4ME's Avatar
02PSD4ME
Oil for 460?
I had a 94 rv with the 460 and used 20w50
Old May 23, 2003 | 08:25 PM
carpe_diem's Avatar
carpe_diem
Oil for 460?
I forgot to say that I will be towing about 9,000 lbs. Does this justify synthetics?
I would prefer a good dino, like Castrol GTX or Penzoil, 10w-30
Old May 23, 2003 | 09:34 PM
mikemc's Avatar
mikemc
Oil for 460?
If you lean towards a heavier oil and are towing a load, how about Chevron Delo 400 15w40 or Shell Rotella T 15w40? These oils are designed to protect heavy duty diesels for extended drains. I still think a good 10w30 dino would be fine, just keep the drain intervals to 3,000 miles.
heavydude
17
Nov 14, 2016 08:34 PM
jamusfam
Apr 25, 2014 10:38 PM
passengerdoorsmud
Oct 30, 2011 02:18 AM
apropos
Oil & Lubrication
Sep 14, 2007 11:52 PM
BigBlue460
Aug 23, 2006 07:52 AM
