New 6.4 owner with some questions
#31
#32
These things are quiet for sure, sounds like a gasser almost. Sometimes miss the sound of the old 7.3 until I get in one an ddrive it for a while. Now I have been checking the message center if Im ready to stop driving to see if it is cleaning but usually can tell at a stop light by the lopey idle. It started cleaning a yesterday a couple blocks before home and when I parked the truck it smelled like it was on fire, and man are the tail pipes hot when that it happening.
I got my guages but they messed up my pipe and sent me aluminized. Now they messed up the shipping on the stainless one.
#33
Mine gets like that at an idle when it's cleaning, if you can't finish a clean, before you shut it off idle it up to 1200 RPM for a couple of minutes to cool down before you shut it down, will also help on burning the excess fuel up since you aborted a clean. Mines in my garage now, about halfway done with the exhaust, should be like a new truck by tomorrow.
#34
I'm going to wait until tomorrow, my aftermarket pipes are giving me issues, tooo tight, and my exhaust pipe spreader is way tooooo small. Might have to run up to the muffler shop tomorrow to open a pipe a little for me. No big deal after I busted my nuts getting that contraption from under my truck, I wouldn't be surprised if the truck sits a little higher on the passenger side for a while, hell that's got to be worth a .5 MPG.
#35
Fuel consumption
Well I just drove a few hundred miles on highway, I checked fuel mileage by hand and I was pretty disappointed. 90% highway mileage with completely stock truck gave me 15.3 MPG.
I got my tuner and now I can use the spartan forum, those guys are saying even w/ delete the best they see is 17-18.
Any thoughts?
PS: my truck smells like a diesel now
Any thoughts?
#36
Any thoughts?
Any thoughts?
#37
#38
?? I am disappointed with the stock fuel mileage, was hoping for more like 17 as a starting number. I have not seen an increase, 15.3 mpg is my base starting number. This was driving very conservatively, mostly highway. My 7.3 easily gets 17 on the highway, I have seen them do 20. I know this is a bigger truck but I think a gasser would do better than 15.3. (Empty)
I am not sure if it would be better in summer because of fuel blend but I will try to do some more calculations in the near future.
Right now I have it on the low setting and man does it launch out of the hole. Also the everything about the shifting is improved. The only thing I didn't like is that the converter doesn't lock in 4th, now it locks in OD.
#39
?? I am disappointed with the stock fuel mileage. I have not seen an increase, 15.3 mpg is my base starting number. This was driving very conservatively, mostly highway. My 7.3 easily gets 17 on the highway, I have seen them do 20. I know this is a bigger truck but I think a gasser would do better than 15.3. (Empty)
#40
If I remember correctly the HS tuner gives you ability to change shift strategies. ? Do you know if you can adjust torque converter lock up?
#42
6.4 problem i had
just a heads took my 2010 f350 6.4 in 2 months ago to the dealer. Starter hung and went out, also they said i was not getting fuel , split the truck apart,noticed i had a oil leak on top of the motor,startig to disassemble ,pulled the heads and 4 cylinders were shot there were metal in the injectors(sounds like pump failed internal) time to chang the engine and exhaust(53500miles on the truck) I have the powertrain and extended warranty from Ford, they said it looks like some water got past both filters but who knows,finally picking it up tomorrow
#43
Warranty coverage
#44
#45
