New 6.4 owner with some questions
I was able to get the fuel filters changed and clean out the f/w drain. I changed the oil even though it looked ok just so i knew what i had. The drain area had the white stuff, was deffinitely due for a cleaning. Thanks for all the tips..
Now for my next issue, the exhaust filter. For the last 2-3 days it seems like every time i get in the truck it gives me the " exhaust cleaning " message and a puff of smoke. I have driven about 100 miles since I got the first message. Kinda strange that i drove 400 miles home from the dealer and no message now it does it everyday?
Any thoughts? I think I will start a seperate thread for this...
Thanks, deffinitely would be a hard thing to get use to. Not guna get use to it much longer. I keep thinking about fuel in the oil every time I see the message pop up.
My biggest concern is that the truck came with a one month warranty from the dealer I got it from that covers anything. I have about a week or two left. If the dpf was bad maybe i could get a new one and keep the old one for "something else"
If I ever have to sell it I dont want to have to buy a new filter.
StanleyZ hit it in the head. After a whole you can usually sense a difference in the way the truck sounds and drives while in Regen and you'll know when it's done.
I am up to 40 miles on my tripometer that I reset last night, so bout 140 total miles since I first noticed the exhaust message. The truck is still trying to clean and now that I know how to check it in the message center I can verify it.
I am thinking about taking it on the highway tommorrow morning before work. How many miles should it take so I can be sure there is problem or not? I was already 20 min late for work this morning because I kept driving around to see if it would complete. Getting pretty rediculous, any suggestions? I have parts on the way hopefully first thing next week but I would still like to know if i in fact have a problem.
On top of that I have a lopey idle when in drive, it steadies right out if I throw it in park. Is this a symptom of dpf cleaning?
Mine will typically take about 10 miles...maybe 15 if towing. I think your issue here is trying to do a cleaning in city driving?
Get on the interstate and get it done. Steady speeds of around 50 mph is much better.
Oh and I reset my trip B once it is complete so I can monitor in between intervals. Once you establish that you may be able to plan a little better.
Hallelujah!
Ok, you all were right. I was ready to go for a highway ride this morning but I never got the message once the truck warmed up. Put some more miles on it tonight and it is behaving so it must be happy now.
That was a terrible experience I hope I never have to go through it a gain. My milage was at like 15-16 before this whole ordeal started now it is at 11.5 .
Strange noises
Well as I have got more comfortable in my truck I have noticed a strange characteristic of the motor. The truck runs great but down in the lower revs (1250- 1750) when baby footing the accelerator the motor gives a kind of rattlesnake sound. As soon as I lay into it it will go away, only under light loadsdown low. Not sure what to make of it, its not as "light" as a lifter tap or as "heavy" as a rod knock. Rattlesnake was the best thing i could think of. Maybe the turbo is creating it? It doesnt do it at idle but it will do it in neutral in the same rpm range.
If I had time I would see if I could find another one to test drive. Until then I figured I would throw it out to see if it sounds like a normal characteristic of these trucks.
#28
#29
#30
Relax. if it's cleaning now (and don't forget that's an ongoing process, it's gonna want to clean every 100 to 200 miles)and driving Ok you're doing ok. Diesels are a bit noisey, even these quite ones. If you have no wrench or check engine on the dash you're probably fine.
I got my guages but they messed up my pipe and sent me aluminized. Now they messed up the shipping on the stainless one.
