Oil Leak
Old Nov 25, 2012 | 08:20 PM
Craig.Parks's Avatar
Craig.Parks
Oil Leak
Ok, here goes. Pulled the 5er this weekend and when we got home I noticed some oil spots under the truck.
Truck is '04 6.0 with '03 engine 100K miles, all stock. The oil seems to be coming from somewhere on top of the driver side of the engine. I also noticed my coolant level had dropped about 1/2 " in the degas bottle and i'm not positive, but I think the oil level has increased on the dipstick passed the max mark. Oil did not smell like diesel. I have drained enough oil to bring the level down between min and max.
No sign of puking on the degas bottle. Temp deltas ran 12-18* while towing. max water 213 and max oil 231.
Any ideas where the oil is coming from? I have never had an oil leak before this trip.
I have attached a couple photos of the oil if it helps any.
Thanks,
Craig
Old Nov 25, 2012 | 08:40 PM
Lilpooh's Avatar
Lilpooh
03 motor, check the ICP sensor and wire/plug harness. Behind turbo, closes sensor to turbo is IPR, the ICP is more toward the firewall.
Old Nov 25, 2012 | 08:43 PM
Lilpooh's Avatar
Lilpooh
Should also point out, sometimes the EGR coolant hose can leak and as its dripping down the motor, it mixes with dirt/oil to make it look like a oil drip. So also check the EGR cooler hose.
Unlikely but not impossible is the turbo drain tube under turbo, it's only a o-ring seal.
Old Nov 26, 2012 | 01:45 AM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
Question
Originally Posted by Craig.Parks
Ok,
Thanks,
Craig
Sorry, I am new here and a new 6.0 owner. I have heard folks make reference to the oil smelling like diesel. Is there a problem if this occurs or what would cause this?? Thanks
Last edited by Stroker 6.0 fan; Nov 26, 2012 at 01:46 AM. Reason: Miss spelled word.
Old Nov 26, 2012 | 07:21 AM
Craig.Parks
I believe one way that can occur is when the injector o-rings are failing and allow the diesel and oil to mix.
Old Nov 26, 2012 | 09:22 AM
69cj's Avatar
69cj
Eliminate the simple things first per Lilpooh's suggestions.
Old Nov 26, 2012 | 09:24 AM
Craig.Parks
Yep, I agree. I'll be taking a look at the ICP this week.
Old Dec 4, 2012 | 11:21 AM
Craig.Parks
Bad ICP was the culprit. What a pain to change it out.
Parts from Tousley and these links really helped.
https://www.ford-trucks.com/forums/8...-icp-swap.html
https://www.ford-trucks.com/forums/8...with-6-0l.html
How to replace early ICP - with pictures - Page 5 - Diesel Forum - TheDieselStop.com
komida
Sep 28, 2017 01:11 PM
zed326
Apr 8, 2011 09:57 PM
joe blow
Oct 24, 2010 11:06 AM
AndeyHall
Sep 25, 2010 06:49 PM
rckrwlr
Feb 22, 2007 11:46 AM
