Modular V10 (6.8l)
Need Help Please
Old Nov 25, 2012 | 04:24 PM
Cyle4's Avatar
Cyle4
Need Help Please
Let me start with, the problem stared when we changed the fuel filter. I got a code reader and the codes that it is giving me are 2104, 2107, 2110, and 2112. I have had this problem in the past and I changed the motor on the throttle body and that cleared the problem up. This time I have changed the Throttle body, the TB motor and the TPS and nothing has helped not sure what to next, have read some other stuff about ignition coils but not sure where to start any help would be greatly appreciated. The truck is a 2005 F350 4x4 SRW 6.8l with about 103000 miles had new motor installed at about 75k.
Old Nov 25, 2012 | 04:32 PM
86f350's Avatar
86f350
welcome to FTE.... check the integrity of the wires going to both the throttle body actuator and the ecm including the throttle switch. Most of the time, if you have symptoms like trany going to a limp mode, the culprit originates from the trany circuit.
Old Nov 25, 2012 | 05:27 PM
Cyle4's Avatar
Cyle4
Thanks will check that out was rechecking the TPS that i have and after put back on i got a malfunction on G coil. Could it be sending a spike to the TPS and causing these problems.
Old Nov 25, 2012 | 05:49 PM
86f350's Avatar
86f350
I guess it could be possible but Im not sure. Hope ya get it figured out though. Keep us posted.
Trouble93
1978 - 1996 Big Bronco
Aug 4, 2023 08:27 AM
makuloco2000
Transit Connect
Jan 20, 2014 10:46 PM
LilToe
Dec 4, 2012 11:53 AM
026TB4U
Apr 29, 2012 09:14 AM
irishguyincc
1983 - 2012 Ranger & B-Series
Jun 15, 2005 01:08 AM
