1978 - 1996 Big Bronco
replace t case speedo drive gear
Old May 22, 2003 | 09:47 PM
davesanrn's Avatar
davesanrn
Is it possible to replace the speedo drive gear in a transfer case without removing the t case from the vehicle and totally dissassembling it?
If so, could someone give me some hints on doing the job?
vehicle is 85 full size bronco, 302, 4 speed, manual transfer case.
Thanks a bunch, Dave
Old May 22, 2003 | 09:53 PM
steve83's Avatar
steve83
Yes, just pull the rear output yoke, the speedo cable (with its gear), and the snap-ring that retains the plastic speedo drive gear, then slide the gear out. It's a good opportunity to replace the rear seal, too.
Come to think of it, I'm pretty sure you HAVE to pull the seal... Check here.
Old May 23, 2003 | 12:41 PM
fcarruth's Avatar
fcarruth
Steve83, what do you mean "rear seal" ? I replaced my speedo gear in my 89 and don't remember any seal. Heck, I may have totally over looked it also.
Old May 23, 2003 | 05:48 PM
steve83's Avatar
steve83
The rear output seal of the t-case. Where the rear output shaft comes thru the rear housing and the yoke attaches. Did you look it up thru that link?
