Alternator affecting my MAF?
If it holds a charge overnight, look to a leaking/shorted alternator diode, faulty electrical equiptment, or wiring problem with something in the vehicle, like a lamp thats not turning off, stuck on brake light switch, or maybe the GEM isn't timing out & going to sleep like its supposed to after about 20min, or maybe an acting out piece of add on equipt.
More thoughts for consideration.
Likewise if you have a multimeter, you could check the fully charged battery no load voltage, then check it every few hours to see if its dropping, which would indicate an internal cell problem.
Or with the battery B- cable disconnected, rig your multimeter in series with the B- cable & battery B- post to monitor parasitic load current in amps, to see if the GEM goes to sleep, or if something else is drawing too much current & causing the battery to discharge.
Did this problem come about suddenly after some event????
Back on the 12th you were gonna disconnect & charge the optima battery & leave it disconnected overnight to try & determine if you had an internal battery problem with a cell self discharging. Then if that was ok, you were going to hook up your multimeter in series with the disconnected B- cable, wait a half hour or so, to let the GEM module go to sleep, then measure what your parasitic drain on the battery is, to see if excessive parasitic drain from something else was discharging the battery overnight, SO, what were the results of those two tests?????
Then yesterday you began talking about the purge valve solenoid, then today saying the engine runs ok when "its disconnected", but we don't know whats been disconnected???? If it was the vapor canister purge valve that was disconnected & the fuel intake fill tube is leaking at the tank, it'll mess up the vapor recovery system operation, so you need to get that whole end of the assembly replaced/put right, so things are working as designed, so the computer doesn't get as confused as I am about whats going on!!!! lol
Fasten the multimeter + lead to the disconnected battery B- cable & the multimeter - lead to the battery - post & note the parasitic drain current.
Then check it say 45 minutes later, after the GEM times out & puts everything it controls to sleep & the parasitic current should drop to say around the 50ma range, depending on how many electronic things with memory, you have plugged in on the battery circuit.
Things like stuck on brake light switch, glove box, trunk, under hood, or dome lights, clocks, radios, phones, CD, or tape players with memory, or a stuck CD or tape in the player, CB or short wave radio, or other after market electrical/electronic equiptment, can cause the system to draw more parasitic current, so be sure to check out All that apply, to make sure their off line.
A leaky or shorted alternator diode can drain the battery.
If after say 45 min, the parasitic current is around 100ma or more, begin inspecting the above things, maybe begin to pull fuses one at a time, to try & determine which circuit has the most parasitic current draw, then begin a systematic inspection/disconnection of all electrical items on that circuit.
On the CEL that comes & goes, it suggests its an intermittent problem, like maybe an old lazy O2 sensor would cause, or maybe a misfire that corrects itself, ect, but you should have a "pending" code stored in CM for a number of drive cycles, if the CEL has been lit, so be sure to look for stored "Pending" codes.
