Tuner Help
Old Nov 21, 2012 | 12:50 PM
Iaff113's Avatar
Iaff113
Tuner Help
Hello
I recently bought this 06 F350 with an edge wiring harness in it. Does anyone know if I can just buy a head unit for it? or do I have to get a whole new kit?
Old Nov 21, 2012 | 01:24 PM
mustang_309's Avatar
mustang_309
That just looks like the EGT probe. If you dont have the Edge insight you should just be able to buy the Edge insight and it should just plug right in to it. But you may want to consider getting an EGT probe with the EAS starter kit so if you want to expand later you can without having to buy a new EGT probe that is compatible with the EAS (edge accessory system).
Edge Products| Products
Old Nov 21, 2012 | 01:42 PM
Iaff113's Avatar
Iaff113
So I should just pull that out and put a whole new prob in it? Is it for a tunner or just a to monitor temps?
Old Nov 21, 2012 | 02:10 PM
Iaff113's Avatar
Iaff113
im not interested in running a tunner on the truck. But will the insight act like the scangauge?
thanks
Old Nov 21, 2012 | 02:13 PM
mustang_309
thanks
Yes, in fact that is all the insight is is a set of gauges.
Old Nov 21, 2012 | 02:49 PM
Lilpooh's Avatar
Lilpooh
Your Edge product will depend on the design of the plug on the end. They take a Molex connector. Count how many pins the plug has, if it only has 4 pins then its the original style insight. If the plug has 6 pins, then it's for the newer insight.
In the pic below is a 4 pin Molex plug style that the older Insights use. The older Insights look like the Gryphon's from PHP, the second pic is what the older Insights look like.
Old Nov 21, 2012 | 05:49 PM
Iaff113's Avatar
Iaff113
Heres what I have
Old Nov 21, 2012 | 08:35 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
If you follow that stainless steel coated wire down to the engine, you would find it would be in the drivers side exhaust manifold. It is used to measure the exhaust temprature before the turbo. Most usefull when towing or tuning and used with a edge product. They cost around $80 for a new probe/wiring, i would buy a matching edge gauge.
Old Nov 21, 2012 | 10:21 PM
Lilpooh's Avatar
Lilpooh
Heres what I have
That I don't know, I only thought that Edge has two style Molex plugs. 4 pin for the older style, and 6 pin for the newer style. Looks like yours is a 8 pin.
Old Nov 22, 2012 | 06:09 AM
Iaff113's Avatar
Iaff113
hey if you buy a new insight does it come with the harness or is it just the unit?
coolfeet
Computer Chips & Tuners
Jun 16, 2018 06:47 AM
Arrowman400
Ford Truck Parts for Sale
Sep 26, 2017 10:17 PM
Fellenz
Apr 16, 2015 04:05 PM
King-bRanch
Dec 20, 2012 08:30 AM
jkiacz
2004 - 2008 F150
Jul 28, 2007 05:41 PM
