Extra HP?
Remember exterior eng mods may put you in a different class?? And then the fun really begins....
Yes on the timing, intake, carb, headers and elec up grade. Then comes the clutch, or transmission, then the 1310 u-joints and the in put/out put flanges on the t case and HD drive shafts. Then chrome moly axles and a locker and a spool and drive flanges and traction bars, regearing the axles will come in with bigger tires. Then the front end blows up when you launch out of a hill and a hole with the juice just a making that 390 scream and you will be looking for a D60 and stuff it with $$$
Maybe regearing should be right in there with the timing, intake and carb?
Here you go as a idea...EB but you get it right?
http://www.google.com/url?sa=t&rct=j...bLFalqqJynontQ
Well I had plans on upgrading my axels for sure...what do you think about 4:11 gears?
A set of fans out of a taurus are a common swap and easy to do. So this truck is mud runner now only? Get started on water proofing toy elc compartment and electric items in there. The distributor is #1 and coil.
With that 6' lift and 38's or 39's toy are planning on running as long as the tires are getting traction from some HP mods, you should stay on top and the rad outa the mud.
Check out this
Check out this
Look up the last post tech thread sticky for info on electric fans. The dual Taurus or single monster Lincoln Mark VIII from the JY is a good low buck solution.
