Clunk when starting.
Old May 22, 2003 | 01:41 PM
allena's Avatar
allena
Question Clunk when starting.
I have a '94 4WD F-150 with 120,000 Miles on it. When I start slowly from a stop, I get a clunk and a groaning sound from the front. Any ideas what this may be? I'm thinking maybe U-Joints, but I don't know how to check/verify this. How does one go about testing U-Joints to see if they are still good?
Old May 22, 2003 | 10:25 PM
steve83's Avatar
steve83
Set the e-brake, put it in Neutral, crawl under it, and see if you can twist any part of the driveshaft while any other section remains still. Even the TINIEST bit means a problem.
But it sounds more like your frame rivets or radius arm bushings.
Old May 23, 2003 | 11:34 AM
allena's Avatar
allena
I'll try that, thanks.
-Allen
