what year 400?
Old May 23, 2003 | 05:44 PM
baddad457's Avatar
baddad457
what year 400?
The 351M rods are the same as the 400's rods, all you really need is the crank.
Old May 23, 2003 | 06:03 PM
CJJTulsa's Avatar
CJJTulsa
what year 400?
Originally posted by baddad457
Go back and check that 72 400 to see what transmission is behind it. Some of the 72's had FMX transmissions and the blocks were cast with the small block bellhousing pattern to use with the FMX. These blocks are worth much more than the run of the mill 400 blocks. A bare small block pattern 400 block sold on ebay a month ago or so for $425.
Funny you should mention that, because that is precisely the reason I took the road trip from Tulsa. It wasn't an "FMX" block, but I do have one of those blocks in my garage. Mine is an MCC block, and I'm still looking to find a CF cast one as I'm still a little paranoid about the MCCs cracking problems. If I can't find one, I'll probably go ahead and build that block one of these days. I was looking for a 73 Ranchero, that's what I found mine in. I did find a 73 Torino, but it was a 302. The guy that sold that block on e-bay at one time had around 3 of them. I'd still like to snag that 2V Cleveland, I'm 100% sure that block is a standard bore. I need another block to trip over like I need a paper ***. But I'm still 400 FMX hunting.....
crawlfish's Avatar
crawlfish
what year 400?
Somehow or another I missed that fact! I thought they were same length but to that the wristpin size was smaller on the 351m so it had to be bored and a bushing inserted to use with 400 pistons.
Please verify!
Old May 23, 2003 | 06:24 PM
Brian S's Avatar
Brian S
what year 400?
351C pistons are the same height as the 400 pistons with some minor variations. 351M/400 rods use a .975" pin vs the 351C .912" pin.
Old May 23, 2003 | 08:23 PM
crawlfish's Avatar
crawlfish
what year 400?
That was what must have thrown me! I'd been looking at getting pistons for 351c and these would have to be bushed. Okay, so now I'm down to getting a crank, and this'd have to be turned I reckon for it to be useful. Now I'm looking at a crankkit with pistons vs. a donor block.
I think I'm finally back to where I arrived before I had to drop the project.
Okay, so much for playing catch up. Now I'll hunt a source for the crank and piston kits, add all the things up and see how I come out.
I guess its best to drop the hunt for a donor?
Old May 24, 2003 | 07:16 AM
baddad457's Avatar
baddad457
what year 400?
If you were closer, I'd sell you the built 400 in my kid's truck. I'm fixin to pull it and reinstall the stock 400 that was in it when I bought it. The built 400 has a year's running time on it. The only thing wrong is the excessive piston to wall clearance, it has an annoying rattle in it at steady speeds. It's been like this since it was rebuilt last year, so far it hasn't hurt anything. A fresh block bored to match the pistons would cure the problem. We're gonna sell the truck and get something else for him to play with.
Old May 24, 2003 | 11:10 AM
Bill_Beyer's Avatar
Bill_Beyer
what year 400?
Just an FYI, I found a .020/.010 400 crank on eBay a couple of years back for $65 +shipping.
Old May 24, 2003 | 10:21 PM
crawlfish's Avatar
crawlfish
what year 400?
Baddad, thanks for the offer. where u live anyway?
Bill, thanks I'll check ebay out, see what I find... guess it wouldnt hurt to keep checking there see what I find.
Old May 24, 2003 | 11:17 PM
baddad457's Avatar
baddad457
what year 400?
I'm in south Louisiana. I go to Georgia every so often ( I drive a truck) but trying to haul a motor in back of the cab, isn't practical. I was planning on selling the motor complete, less the carb, distributor, water pump, alternator, & P/S pump. It's got 351C forged flattops, ported and polished 400M heads,milled .030, the block is decked .010 , Comp Cams 280H cam ( 280 degree .530 lift) Crane rocker stud conversion kit, big chevy rockers, rods have been resized and fitted with ARP bolts, crank is 10/10, Intake is a Weiand 8010 dual plane. Ford Racing finned aluminum valve covers, rear sump oil pan ( for a 80-82 pickup but it also works on a 77-79)
Old May 25, 2003 | 07:02 AM
crawlfish's Avatar
crawlfish
what year 400?
Built for performance, for sure! If you don't mind me asking, what happened to create the "piston to wall clearance" problem?
Old May 25, 2003 | 07:50 AM
baddad457's Avatar
baddad457
what year 400?
When I brought it to the shop that bored it, I told them to leave a .006 in the piston to wall clearance. This is about what I used on a 427 & a 390 back in the 80's with forged pistons. Never had a fitment problem running that clearance. But I never went back and checked up behind them , which now in hindsight, I should have. I just put it together. I have switched machine shops since and the guy who does my stuff now told me not to worry about the rattle, he's seen a few like it that ran for years like it and they never had problems. Like I said it's been running a year now with a 16-17 year old driving it and it's held up fine. The truck it's in ain't in the best of shape and the boy has lost interest in restoring it, so I'm going to pull this motor and stick the 400 that came with it back in to sell the truck, this will be the only way I can recoup my cost's in it.
400 .040over
Nov 22, 2011 06:48 PM
79-400-POWER
Jan 26, 2007 12:10 AM
DirtyLittleSmurf
17
May 10, 2004 10:24 AM
rogue69
15
May 26, 2003 05:51 PM
Zed
Jun 22, 2002 11:18 PM
