Wheel well / Supercab rust
Old May 22, 2003 | 11:27 AM
johnsonmtz's Avatar
johnsonmtz
My '93 Supercab seems to have gone on a weight reduction program. I'm trying to decide whether to keep the truck (it's paid for!) or go with something newer. To keep it long term, I'd like to address the rust.
I've seen many Fords from the early to mid 90's with the exact same rust pattern....right over the wheel wells and in the rockers of the Supercab.
So my question is how much should it cost to have a shop cut out the bad areas, weld in new metal, and paint it? Also, is this idea even worth it since rust will most likely develop somewhere else?
Interior and everything else looks fine, it's just these four nasty rust spots.
Thanks,
KJ
Old May 24, 2003 | 01:46 PM
Ford_a_holic's Avatar
Ford_a_holic
I have a 92 and had the same problem i would just do it yourself. I cut out all the rust and then filled it with fiberglass it looks brand new. It could only take one day to do. If you decide ill tell you a few tricks
Old May 25, 2003 | 05:21 PM
randallc's Avatar
randallc
I have the same problem with my 1990 F-150. I purchased the patch panels and was all ready to do it my self. But then I noticed that it has rust on the inner panel as well.
When you repair using a patch, you will get minor warping on the box, and you will have to spend hours using a block sander to get it straight again.
So, I decided to take it to an auto body shop and showed them the problem areas, and showed them the panels. They told me that it would be about $650.00 CDN to replace the panels, not including the body work to get it straight again.
I decided to think about it for a few days and look at the option of replacing my box all together. After about 15 phone calls I found a number of good boxes for sale. They all ranged between $500.00 and $1200.00 CDN (Canadian $). I took a look at a few of them and decided to get one that cost me $600.00.
I am now in the process of using POR15 on the underside of the box to prevent future rust problems and am going to replace it next weekend.
While I have the box off, I am going to POR15 the Frame, and gas tank as well.
So, I figure for a bit of extra $ I will have a near new condition box, that is protected from rust for years to come, and the frame is going to look good as well.
If you go this route, look in the papers, call the wrekers, and call the tow yards.
Towing companies purchase new trucks and take the boxes off. That is where I got mine from. It was just some guy who had 3 tow trucks and had a few boxes laying around.
Good Luck.
Randall
Old Jun 18, 2003 | 07:08 PM
supertruck's Avatar
supertruck
Where abouts and who did you locate these boxes from if I may ask.Redoing a 76 ford 4x4 and it is desperately in need of one.
I just ordered a set of 8 foot skins,but they might look like hell if
they are not stamped properly(jobber).600 bones ,even it needs some repair is definately the way to go.Thanks for any info
Old Jun 18, 2003 | 11:04 PM
randallc's Avatar
randallc
Look in the papers, call the wrekers, and call the tow yards.
smblokford
2009 - 2014 F150
22
Mar 27, 2014 09:33 AM
hbkirishwarrior
18
Jan 30, 2012 07:15 PM
alz
Paint & Bodywork
Jul 28, 2007 02:38 PM
aaronlockhart
Paint & Bodywork
May 6, 2007 04:56 AM
pipercub
Paint & Bodywork
Jul 2, 2004 10:23 AM
