5r55e problems
Old Nov 18, 2012 | 03:52 PM
i866508's Avatar
i866508
Unhappy 5r55e problems
truck has periodicaly had 2-3 shift problems revs between shifts 3or4 times in last year.than last itme totaly went into netural and od light flashins. shut off ,restarted and allok for about 3 weeks.then didit again and only way to get to move was use 2nd gear.pulled valve body down and found gasket on top of plate blown .replaced both gaskets but didn't change problem. reverse and in drive have to rev to get to engauge but if you move slector to 2 or low will fulley engauge into gear and shift ok
any suguestions lost at this point ??
Old Nov 18, 2012 | 10:38 PM
yorky's Avatar
yorky
try some Sea Foam Trans Tune Transmission Treatment. some ppl have posted good reviews that it helps with same issue
Old Nov 9, 2025 | 08:52 PM
SamN's Avatar
SamN
1st Gear
'02 3.0 auto with flashing OD and code that shows is p1780. I have flare from 1-2 shift and I don't feel any 1st gear braking. Feels like truck starts in 2nd gear or that there is very little difference between the first two gears. Can a blown valve body gasket cause the p1780 code? 150k miles but trans was rebuilt last year. Thanks for any feedback.
meiser
Oct 13, 2020 08:25 AM
Rich7944
1983 - 2012 Ranger & B-Series
Aug 11, 2015 01:11 PM
danielp
May 12, 2004 05:05 PM
bjvirus
Offroad & 4x4
Sep 12, 2000 09:59 AM
