77-79 Ford
Old Nov 17, 2012 | 11:21 PM
happyheber's Avatar
happyheber
77-79 Ford
I asked this over on the Utah board, but I am anxious to get an answer from someone. Can anyone tell me what years did Ford make 4 wheel drive fully boxed front ends? One other question does anyone know what a used 460 is worth? This one is out of a 71 lincoln. I belive it has 365 horses and 500 pounds of torque. Correct me if I am wrong. I have just discovered this board. I have read pages and pages which I am sucking all in. Thanks in advance.
Old Nov 18, 2012 | 12:39 AM
radar457's Avatar
radar457
if you mean the solid case front end they made that up to 79. After that they went to the independent suspension front end piece of crap. except in the 1 ton they are still solid case.
As for the 460 that depends in what part of the country you are in. Here in Ks it would be worth 350.00 to 450.00
Old Nov 18, 2012 | 09:04 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You mean a solid front axle? Then yea up to 79 in the 1/2 and 3/4 ton. Or are you talking the "boxed" highboy front frame piece, thats under the front bumper?
Between the front frame horns? I believe that idea went away with the HB design in mid 77.
Unless I am really confused about this boxed question. Can we have a little more description information as to what you are calling boxed.
Old Nov 18, 2012 | 10:05 AM
happyheber's Avatar
happyheber
talking about the frame being box in
Old Nov 18, 2012 | 10:31 AM
GOVTMOD's Avatar
GOVTMOD
That is the high boy frame that was discontinued after '77 1/2 F250.
Welcome to the FTE boards. I never worry about hanging out in the UT board. Just here mostly lots of very knowledgeable and helpful folks which have made a ton of difference with my F-150.
Old Nov 18, 2012 | 11:06 AM
happyheber's Avatar
happyheber
now i seen a 79 250 boxin ??
Old Nov 18, 2012 | 11:33 AM
fordcrzymike's Avatar
fordcrzymike
All highboys are 250s
Old Nov 18, 2012 | 11:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
One other question does anyone know what a used 460 is worth? This one is out of a 71 Lincoln.
LDS: "Ye may not know the truth of all things" .. if the 460 info is wrong.
Did you remove the 460 from a 1971 Lincoln yourself, or did someone tell you that's what it's from? If you did remove it yourself, how do you know after years 41 have passed by, if it was the original engine?
D1VE-6059-AB = Block casting number: 1971/73 429 - 1971/78 460 and some 1979 460's. 429/460: The block and bore is the same, the stroke is different. So, is it a 429 or a 460?
429: 1968/73 Ford/Thunderbird/Merc Passenger Cars // 460: 1968/78 Lincoln/Continental Mark III/IV/V / 1972/76 Thunderbird / 1973/78 Ford/Merc Passenger Cars / 1973/79 F100/350 / 1975/97 E250/350 / 1983/97 F250/350.
Old Nov 18, 2012 | 12:00 PM
happyheber's Avatar
happyheber
this
77 f250 is not a hiboy but it is boxed fram
Old Nov 18, 2012 | 12:07 PM
happyheber's Avatar
happyheber
bill where do i look for no. and did ford f250 have all box frams 70s
Old Nov 18, 2012 | 12:11 PM
NumberDummy
This 77 F250 is not a High Boy, but it is boxed frame.
High Boy: 1967/76 F250 4WD, 1977 F250 4WD assembled before serial number Y20,001 (February 1977). Have a divorced transfer case.
1977 F250 4WD's assembled from serial number Y20,001 are not High Boys, have a married transfer case, as do 1978/79 F250 4WD's.
Old Nov 18, 2012 | 12:38 PM
77&79F250's Avatar
77&79F250
Casting #'s behind the starter area for the block.....I believe.
Old Nov 18, 2012 | 01:09 PM
happyheber's Avatar
happyheber
thank you so are 67-79 boxed in
Old Nov 18, 2012 | 01:15 PM
77&79F250's Avatar
77&79F250
77.5 and up are C channeled from front bumper to the front of the moter mounts perches and then right behind that they open up, all the way back.
I'm pretty sure they did not BOX the whole frame at the factory on these ol things??
ND chime in here any time, ya ol pro, cause I know you will know for sure.
Old Nov 18, 2012 | 01:31 PM
happyheber's Avatar
happyheber
we want to know if the frame that was boxed from the bumper to the back of the motor mounts except for a few inches 3-4 maybe at the front for leaf spring mounts not the hi boy style that has motor area boxed and front foot or so c channel i know they are on the 79s but i have one claimed to be a 77 with that same frame so did they make them from 77-79 or just 79? and did any of the "high boys" have the same frames as the 79 boxed? hopefully ND can help us? thanz again for the help
