Sponsored by: Auxito
Burning Oil?
Old Nov 16, 2012 | 11:00 AM
ski1491's Avatar
ski1491
Burning Oil?
Got a 1999 F-150 4X4 Lariat that is a great old truck. It has about 120K on it and I'm having to add a quart of oil after about 2-3 thousand miles. Any suggestions, runs great and seems the milage is too low for rings or even valve stems, could be wrong. No real visible smoke and it runs great. No leaks, driveway is clean every morning. Appreciate any advice or suggestions, thanks
Old Nov 16, 2012 | 11:12 AM
LucasMN's Avatar
LucasMN
How does the coolant look?
Check on the exhaust side and above the exhaust. Could be hitting that and burning off.
Old Nov 16, 2012 | 11:54 AM
fordcrzymike's Avatar
fordcrzymike
Could also be a stuck pcv valve
Old Nov 16, 2012 | 12:08 PM
ski1491's Avatar
ski1491
Two great leads, I'll have a look at the coolant and exhaust manifold area and change out the PVC valve, thanks much
Old Jan 10, 2013 | 12:04 PM
ski1491's Avatar
ski1491
Okay, got a new twist to this question. Took the truck in for a gas tank strap recall and the mechanic noted on the inspection it was leaking oil from the head gaskets. Is that even possible without loss of performance and compression? Don't mind fixing it, however just wanted to know if this is a probability. Thanks in advance for the assistance
Old Jan 10, 2013 | 01:42 PM
galaxie641's Avatar
galaxie641
1qt in 2-3K miles is more than acceptable, mine ate it in half that time and ran perfect.
herdfan75
17
Sep 28, 2017 09:32 AM
Lneidlinger
24
Oct 19, 2016 04:35 PM
CLE-PRE
Jul 15, 2016 09:03 PM
lestro
Nov 4, 2014 02:16 PM
purplelimo
Aug 23, 2005 08:20 PM
