Lie-o-meter
So far I have purchased 19,194.82 gallons of fuel for my truck. At the time of that purchase the odometer read 298,765 miles. I hand calculate the lifetime fuel economy to be in the 15.5 mpg range ( includes any towing ).
fair enough, what does your readout display? While i applaud your monumental display of attention to detail, to me an overall lifetime average fuel mileage is not very useful. particularly if you are going to assume that anything that deviates from that overall average is wrong.
i'm more interested in trip-trip or tank-tank averages. as in, what did i get pulling my boat to the lake, or going to the hills with the camper. that type of thing. which is prone to some error. using hand calcs to indentify
My wife has an identical truck except it is a Lariat version. The overhead computer says 24.5 mpg. Are you suggesting that the computer is more accurate than nearly 300,000 miles of documented fuel logs?
fair enough again, but what do her hand calcs say?
unless the trucks are used identically, it would be hard to assume that one truck has anything to do with another, though.
As you said also, Diesels are different than gas. i know almost nothing about diesel injection, but i don't think they have any means by which to detect or correct for injectors that are not functioning as designed. So, as you said, when hand calcs and the display start differing wildly, one may suspect a fuel injection problem.
I was speaking about gasoline engines, i don't know enough about diesels to speak with any sense of confidence.
for a diesel, i could be convinced.
agreed. but keep in mind that those instantaneous readings are what is used to calculate the average. if one is to be believed, the other should be as well.
Without knowledge of EXACTLY how much fuel the injector delivers (calibrating), the mpg displayed can deviate from the true mpg, but the offset should be consistent. This is because the computer believes the injector is delivering a particular amount of fuel, but has NO WAY of knowing how much fuel is ACTUALLY delivered. This is because neither the volumetic flow rate of the fuel, nor the mass flow rate of the fuel is ever measured. It has been established that air flow is measured, DESIRED fuel calculated, and injector opening time commanded.
the PCM detects any difference between the fuel commanded and the fuel delivered via oxygen sensor. then uses the trim tables to update the look up (flow rate) tables. this is how the PCM can correct for changes in fuel injector performance over the long term.
When the desired amount of fuel delivered and the actual amount of fuel delivered differ, how does the computer know? It doesn't. Until the difference becomes so great it impacts drivability or triggers an emission control problem.
again, the oxygen sensor detects this difference. an emissions problem will only show up to the PCM once the flow rates get out far enough that the trim can no longer compensate.
again, for gasoline only. for diesel, you are likely correct.
I expect most folks would agree that tank to tank milage estimates are inconsistent, but multi-tank milage estimates are much better. Over multiple fill-ups the difference in where the nozzle cuts off the fuel becomes less significant.
agreed
The example Shake-N-Bake cited for lifetime milage is kind of an extreme example - the difference is where the nozzle cuts off the fuel is nothing compared to over 19 thousand gallons!
agreed
I use the computer as a guide for milage getting better or milage getting worse. I use my hand calcs for what my actual average milage is.
so how does your many tank average compare to the computer averaged over the same period of time? i've never really tried it, but if you are correct, the two numbers should start to converge as the errors in tank fill start to become increasingly insignificant.
That would work too, but 5 gallons is the calibrated amount, so it would be the most accurate, that's why i say to use exactly 5.000 gallons.
words added to fool browser[/COLOR]
On a serious note, while I agree that the PCM adjusts fuel trims based on the oxygen sensors, how does it know exactly how much fuel is being burned? Is the MAF sensor 100% accurate?
Something to think about. I'd like to add that I have had a few lie-o-meters ove r the years, and while some of them are consistent I have never seen one consistently right. My Fusion's LOM is almost always 1.5-3 MPGs low based on hand calculating. This is based on always resetting the LOM before starting the car after a fill-up as well as tracking every single tank the car sees.
Fusion (Ford Fusion) | Fuelly
How does the PCM know exactly how much air is being consumed? Does anyone really think that MAF sensors are 100% accurate? What about oxygen sensors, are they 100% accurate?
Furthermore does the PCM assume fuel consumption is directly related to air intake through the MAF? This would be the only way the PCM could compensate for worn injectors with the help of the oxygen sensors, because under this condition fuel delivered would not be constant with a given injector pulse width. It would vary, which would be why fuel trims exist.
So the only way for the PCM to truly adjust consumption estimates would be for it to ignore injector pulse width and calculate based on the MAF sensor and possibly a correction factor with the fuel trims. But we all know that's not the way it works; in fact the LOM on the older Super Duty trucks is directly wired to read injector duty cycle. Which means that it's not possible for the LOM to calculate based on fuel trims or air consumption, as the LOM doesn't have access to this information. So in plain english, my LOM doesn't care if the injector tips are worn.
Something else to consider is that fuel flow for a given injector pulse width will vary based on fuel pressure at the rail. More fuel pressure means that more fuel would be going through the open injector nozzle in a given time. But here's the catch: all the older SD trucks don't even monitor fuel pressure! The PCM calibrations rely on that pressure being within a given range to deliver the appropriate amount, which is yet another reason for oxygen sensors to be there for mixture adjustment.
So in a nutshell the fact that we have oxygen sensors and variable fuel trims precludes the PCM from being exact on its' fuel consumption. Because if fuel delivery were precise all the time there would be no need for adjustment. And without 100% accurate oxygen sensors, MAF sensors, and MAP sensors there is no way for the PCM to know exactly what's going on without some sort of variance.
By the way my Excursion is also consistently off by ~0.5-1 MPGs.
Every once in a while after refueling, the DTE will still say "20 miles to empty" or whatever it said before I shut it down to fuel. Then a couple minutes later, it'll switch to "550 miles to empty" or somewhere thereabouts. So if it was calculated with the conditions it knows at startup, how would it correct itself when it figured out that it had 36-ish gallons more than it thought it had? Or even more interestingly, what if you never shut down to fuel? The display would be wildly off. That isn't the case either.
Secondly, if I were to drive my truck regularly for 2 months, it would have a pretty good idea of how much fuel it is using. Then one day, I go hitch up my 37' fifth wheel camper. After it's all hitched up and I start the truck, you're saying that the fuel consumption numbers are loaded into the DTE calculations. The problem is that if I drive all day long with the camper, the truck should be calculating DTE based on empty numbers. But it doesn't. It keeps up very nicely with how much fuel is actually being used.
My owners manual says: "DTE is calculated using a running average fuel economy, which is based on your recent driving history of 500 miles." Through experience, I know that the DTE display is constantly learning when fuel use drastically changes, such as when a trailer is first hitched up or it is dropped off. I don't think the conditions at startup are the conditions that it always uses. I have a hard time accepting that a model year 11 would go backwards in this regard from a model year 05.
Just my thoughts.
i feel the dte is using the last, say 50 mi.
The sg2 gives inst avg along with trip data.
On flat highways it seems the values reflect better.
City driving or towing the averages swing so much the
Values are less likely to be close.
sort of like dead reckoning when you change course/speed
a lot with a strong wind on a hill.
I tried several times to sit down and read through every post in this thread, but without my pocket protector it just ain't clickin'.
I fill my truck up once a week normally. My lie-o-meter has been mostly dead on with my hand calcs. A few times I could say it most was .2 off. And that was weeks when trailers were pulled a lot.
