1978 - 1996 Big Bronco
Changing Transfer Cases
Old May 21, 2003 | 11:53 PM
Broncolio's Avatar
Broncolio
Question Changing Transfer Cases
I have an 88 Bronco with a blown bw 1356 electric shift transfer case. I want a manual shift model. Can I make the swap? The wiring for the 4x4 annunciator lights is there as well as the hole for the shifter. How bad can it be and what should I be careful of?
Old May 22, 2003 | 07:49 AM
steve83's Avatar
steve83
It should be easy. Several people have done it, but have you read this?
Old May 22, 2003 | 09:16 PM
Broncolio's Avatar
Broncolio
Thanks for the info, but already checked out the motor. Split the X-fer Case and it looked like a grenade went off in there. Chain and shift levers broken as well as the worm gear for the shift motor stripped. Totally blown. Down to the replacement options now. I'm saving that link though..... Thanks.
Old May 22, 2003 | 09:26 PM
justshootme84's Avatar
justshootme84
The swap from electric to manual is fairly easy. You need the shifter bracket that bolts to the transmission from the manual t-case, and you usually can pick up a used, manual-shift B-W13-56 for $200-$300.
driptorch970
2009 - 2014 F150
Dec 21, 2010 11:39 AM
Katmandu
Nov 19, 2008 08:38 PM
mickelsons
Nov 29, 2007 02:10 AM
2pfspiff
Sep 13, 2007 08:28 AM
WesternAuto17
Oct 12, 2006 09:55 PM
