Dorman Front timing cover problems???
Old Nov 25, 2012 | 10:01 PM
mjbavid's Avatar
mjbavid
How did you machine it?
How did you machine it on a lathe or file?
Old Nov 25, 2012 | 10:03 PM
ATC_250SX's Avatar
ATC_250SX
Ha ha a drill press and a home made tool.. It was interesting to say the lease
Old Nov 25, 2012 | 10:30 PM
mjbavid's Avatar
mjbavid
How much did you remove? and did you check with a scope afterwards?
Old Nov 25, 2012 | 10:55 PM
ATC_250SX's Avatar
ATC_250SX
Aprox .185 and no. It ran, and has been back in service a week now with over 1,000 miles on the clicker
Old Nov 25, 2012 | 11:08 PM
mjbavid's Avatar
mjbavid
Dorman
We took off .080 and will recheck tomorrow. I have shim pack to shim out if needed. Thank you for the info, Mike.
Old Nov 25, 2012 | 11:13 PM
ATC_250SX's Avatar
ATC_250SX
Are you having the same issue with a dorman cover?!?
Old Nov 25, 2012 | 11:19 PM
ATC_250SX's Avatar
ATC_250SX
To get my approximate depth I removed the o ring from sensor and cut duct tape " shims" and stuck on end until contact was made. Then measured the thickness of the duct tape build up, subtracted .020" from the thickness and machined to that length. The air gap should be .020 to .025"
Old Nov 26, 2012 | 07:01 AM
mjbavid's Avatar
mjbavid
dorman
Yes, we had same issue only I overhauled the whole engine. Had a no start and would only fire intermittantly. I installed a cps out of a dt466 got it running but is dying sometimes and idle erratic underload. So we machined the stock cps and will recheck depth today. Sure wish I used a ford timing covver. Mike
Old Nov 26, 2012 | 07:18 AM
ATC_250SX's Avatar
ATC_250SX
Yes me too, and don't waste your time with dorman, they are unreceptive to the idea there cover could be at fault I wAs told by them they would only send me another cover.... After they recived the defective cover.
Old Nov 26, 2012 | 06:59 PM
mjbavid's Avatar
mjbavid
dorman
Thank you very much for the help, you saved me alot of greif. Hope we can save other people the pain. Regards, Mike
Old Nov 26, 2012 | 07:15 PM
ATC_250SX's Avatar
ATC_250SX
Yes I hope people see it Before buying it. I have a bald spot from pulling out my hair on this one. Did you get yours running?? And approximate how much did you remove from sensor base?
Old Nov 26, 2012 | 08:16 PM
mjbavid's Avatar
mjbavid
Dorman timing cover Defective
My son removed .080 off the flange I think this will work without shims, if I need shims will do that. He used a lathe at his work. I will install the International#1876736C91 this is the newest CPS for the 7.3 this is recommended by Jody Tipton at DP Tuner and many others. Mike
Old Nov 26, 2012 | 08:23 PM
  #28
ATC_250SX's Avatar
ATC_250SX
Is it the blue colored sensor?
Old Nov 26, 2012 | 08:28 PM
  #29
mjbavid's Avatar
mjbavid
Dorman timing cover Defective this is the one
Old Nov 26, 2012 | 08:29 PM
  #30
mjbavid's Avatar
mjbavid
Droman timing cover defective
It is dark grey almost black this is a picture. Mike
