trouble code C1979
Old Nov 14, 2012 | 06:48 PM
beckman's Avatar
beckman
trouble code C1979
hi guys i have a 2007 ford f150 and the 4wd will not engage at all checked vacum lines they all look intact wondering if it could be the IWE solenoid and is there any way to test the IWE solenoid thank you
Old Nov 16, 2012 | 08:42 PM
greg1971's Avatar
greg1971
Hello, this might be of some help to you or it may not.
Turn the radio off and start the engine.The cab should be quiet, then turn the 4wd **** to 4wd- the solenoid should make a faint "click" noise to determine if its working or not and the instrument panel "4x4" light should come on. The physical solenoid is located on the passenger side under the hood near the firewall.almost in the upper left hand portion when opening the hood.
Hope this helps.
Old Nov 16, 2012 | 10:12 PM
beckman's Avatar
beckman
solenoid
hi it does make a sound when i turn the **** but the sound is coming from the side of the transfer case and not from the solenoid on the firewall and the light doesnt come on in the dash but if you turn it quick enough back and forth it flickers
Old Nov 16, 2012 | 11:14 PM
greg1971's Avatar
greg1971
If the solenoid clicks that's a good sign..it may be the vacuum line not making connection since it sounds like the solenoid is OK. Try this- lightly tap on the actuator motor attached to the transfer case, if you don't use the 4wd much the motor gets stuck, a small hammer can do the trick.<!-- google_ad_section_end -->
Sorry man.
Old Nov 17, 2012 | 09:51 AM
beckman's Avatar
beckman
solenoid ?
there is a vacum line on the drivers side front that is open but it looks like its from the factory open like that
Old Nov 18, 2012 | 03:36 PM
greg1971's Avatar
greg1971
You could check the other side to see if the passenger side is the same. The idea is that when you flip that switch to 4wd Hi the vacuum line releases its vaccum on the line to give you 4wd. I'm not sure anything should be "open" or not. Sounds like the system should be sealed to prevent debris from entering the system. I'm no expert by any means. I wish I could be of more help to you.
Hope you get this figured out.
ario31
1997 - 2003 F150
23
Jun 29, 2020 07:23 AM
gparis
2004 - 2008 F150
Feb 20, 2017 09:34 PM
ke6zmy
Sep 4, 2012 05:01 PM
smittie
1997 - 2003 F150
Apr 29, 2007 10:21 AM
ebraunusa
Dec 16, 2005 09:02 AM
