1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Wider Tires Worse in Snow
Old 11-11-2012, 02:35 PM
truculent's Avatar
truculent
truculent is offline
Have been around for awhile and remember when L78 was a good snow tire. Now it seems the tires are ever wider and I think in the snow ever worse. Am I wrong in thinking a narrow tire will perform better in the snow due to a smaller contact area? That's assuming all other tire factors are equal.
Old 11-11-2012, 02:53 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
You are correct, narrower tires are better in the snow.
Old 11-11-2012, 02:59 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
must better in snow. When we lived in the snow country as a kid all the tires were narrow.
Old 11-11-2012, 03:51 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
As a general rule wide tires in snow push too much snow and not so good.
They also hydroplane easer in water at speeds One thing about that is tread
design it will help but you still stuck with the large tire face to the snow like a snow shoe.
If you going to run wide in the snow put the narrow ones in the front so you
can steer with less effort. Or move to LA California where they don't get snow.
Sean
Old 11-11-2012, 03:59 PM
pro3qtr's Avatar
pro3qtr
pro3qtr is offline
I run 275's all around all season tire in my AWD 400HP TBSS, ZERO issues.............
Tire tread is key
Old 11-11-2012, 04:15 PM
Ian123's Avatar
Ian123
Ian123 is offline
Yeah I know wide tires suck in water. They pull the hell out of my steering wheel when I hit puddles. Narrow tires just slice right through. I assume snow would be the same
Old 11-11-2012, 04:20 PM
pro3qtr's Avatar
pro3qtr
pro3qtr is offline
TREAD,vehicle weight, hardness and compound of tires have more to due then the width of tire.
Seen 185's hydro plain faster then 275's...................
Way, WAY more then how wide !!!!!!!!!!!!!
The Rain Master
Old 11-11-2012, 04:30 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
too narrow and you get too much ground pressure and sink...
too wide and you get too little ground pressure and slide...
This is for powder anyway... packed snow is more like ice.
Old 11-11-2012, 04:53 PM
Ian123's Avatar
Ian123
Ian123 is offline
The Rain Master
Well I can tell you that I've had both 275's and now 325's on my truck. Both load range E. Both with lots of tread. And the 325's pull way more.
I'm not saying you're wrong, but in my experience width was the only variable that really changed and it made a big difference
Old 11-11-2012, 05:07 PM
2ndStroke's Avatar
2ndStroke
2ndStroke is offline
We get couple feet of snow up here each winter, I find that the wider tires try and ride up on top the snow as well.
Old 11-11-2012, 05:23 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i have ran 235/85 16 and 265/75 16 on my plow truck and i did not notice much of a difference but the 265's make still be skinny enough to not cause issues.
on the excursion i also run stock size 265/75 16's in a good studded snow tire and grip is something i never worry about
Old 11-11-2012, 05:24 PM
Buck268's Avatar
Buck268
Buck268 is offline
On-road you want to sink...
Old 11-11-2012, 06:07 PM
TexasRebel's Avatar
TexasRebel
only with momentum... i guess
the only times I've been stuck in snow was because i sank and couldn't climb back up.
The only way out was to pack the snow around the tires to get momentum to get back on top.
Old 11-11-2012, 06:20 PM
pro3qtr's Avatar
pro3qtr
pro3qtr is offline
Funny how tards run studs on BARE roads here.
For years I run spec tires for what i drive on, that and SLOW down !! ROFL
I would LOVE a 35" 9.50 tire, but they don't even make a 33" 9.50 in a SNOW spec.
Plan is Snow flake rated 33" 12.50 15 on the Bronco..................
So wide is the only way on most trucks if U want height ............
Old 11-11-2012, 09:00 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
From Why are Narrower Tires Better for Winter Driving? - Hunter's Ramblings about Performance wheels & tire | Tire Rack
As you're shopping for winter wheels and tires, you'll likely come across the recommendation of going to a narrower tire. This is the exact opposite approach that you would take for summer traction, where wider is better. If you're likely to drive through deep snow this year, you'll want winter / snow tires and wheels in sizes that help put the laws of physics on your side.
The reason for this is that traction is achieved in winter by cutting through the ice and snow. With wider tread, you're more likely to start snow plowing or floating on top of the surface instead of pushing down and through. This floating will result in loss of traction sooner than with a thinner or narrower option. A good way to picture this is imagine a pizza cutter slicing through a pizza.
Another way to think about this is from the perspective of the contact patch. A tire's contact patch or "footprint" greatly influences its performance and is dependent on its profile. The narrower the width, the smaller the contact patch will be. This is the area that makes contact with the ground as rotation occurs. With the vehicle still weighing the same, a smaller contact patch results in more pounds per square inch. This will produce more force on the tire to help it cut into ice and snow and deliver optimum traction for the worst winter will throw at you.
Quick Reply: Wider Tires Worse in Snow
