column shift linkage
Old May 21, 2003 | 11:06 PM
Dirt Head's Avatar
Dirt Head
I have a 74 F-250 with a C6 tranny. The problem I have is the column shifter has alot of slop in it. You can move it about a half inch in both directions when in a gear. I haven't tore it apart yet but am guessing that it is just wore out.
I have looked for a new column shifter but haven't found one. What are my options? Find one at a junk yard in better shape or could I try to fix this one somehow? Thanks for the help.
Jake
Old May 22, 2003 | 01:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
Go thru and isolate the slop at each point and replace parts or bushings as required.
Old May 22, 2003 | 09:27 AM
beartracks's Avatar
beartracks
If you have the wheel off look for the gear "sector" plate. It's a small plate with notches in it the a pin rides in.
