Big snag!!!!
Old Nov 14, 2012 | 12:37 PM
JohnDeereFarmerUSMC's Avatar
JohnDeereFarmerUSMC
Big snag!!!!
Cannot get the front cross member off on the front clip (above intercooler). The passenger side comes up but the drivers side seems like its frozen or locked in, any tips??
Old Nov 14, 2012 | 12:44 PM
JohnDeereFarmerUSMC
Nvm nothing a bfh won't fix
Old Nov 14, 2012 | 12:53 PM
PaysonPSD's Avatar
PaysonPSD
Always nice to have a BFH on hand.
Old Nov 14, 2012 | 12:56 PM
Skip1970's Avatar
Skip1970
try harder!!!
Old Nov 14, 2012 | 01:24 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Hammer or some penetrating oil and a propane torch
Old Nov 14, 2012 | 02:08 PM
Christof13T's Avatar
Christof13T
Got mine out just by man handling and it came out with the intercooler. Going back in was where i needed the hammer and pry bars.
Old Nov 14, 2012 | 03:48 PM
JohnDeereFarmerUSMC
Fuel line disconnection, I have the 3/8 tool how do I do it lol
Old Nov 14, 2012 | 05:37 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Why are you removing it? If to install IC or trans cooler you can leave it in place. I did.
Old Nov 14, 2012 | 08:11 PM
JohnDeereFarmerUSMC
Pullin' the motor :P, an this far it's shocking how much the 6.0 &7.3 are alike in some areas yet very different in others
Old Nov 15, 2012 | 10:32 AM
PaysonPSD's Avatar
PaysonPSD
Slide the tool into the connector to release tension on the garter spring and pull.
This is the typical QD connector.
Old Nov 15, 2012 | 12:24 PM
SkySkiJason's Avatar
SkySkiJason
I know you've already done it, but there is no reason to remove all that stuff to pull engine. I've done it both ways and I will never take all that off again... Not only does it add HOURS to the engine R&R - you have to evacuate and recharge the AC system.
The problem with the piece you are struggling with is the fenders are too close together. You probably ended up pushing them apart to get it out and will likely need to pull them together to get the bolt holes to line up when ya put it back together. A ratchet strap will help with pulling them together.
bronc71
Feb 2, 2017 12:35 PM
Greg Messmer
Sep 4, 2015 07:17 PM
COMPLIT1107
1947 and Older Ford Trucks
Jul 29, 2012 09:37 AM
BigF350
Large Truck
22
Aug 16, 2009 11:57 AM
MrRottnDog
Sep 17, 2002 07:27 PM
