Sponsored by: Auxito
97 4x4 problem
Old Nov 14, 2012 | 11:31 AM
mcmavv's Avatar
mcmavv
97 4x4 problem
bought a 97 f150 4x4 from an older fella who never used the 4x4 option.the one time it was put into 2 high it got stuck and still is.truck runs fine but i need to get it out of 4x4.removed the boot a cover but that doesnt give any access to maybe lube it,so im kinda stuck.truck was only driven for 2 miles with it stuck.any tips?.thanks
Old Nov 14, 2012 | 11:42 AM
fordcrzymike's Avatar
fordcrzymike
Im assuming it's not SOTF, correct?
Old Nov 14, 2012 | 11:47 AM
mcmavv's Avatar
mcmavv
i really dont know
first 4x4 ive ever had.how do i tell.
Old Nov 14, 2012 | 12:11 PM
mcmavv's Avatar
mcmavv
4x4 shifter
is on the floor if that helps.
Old Nov 14, 2012 | 12:36 PM
fordcrzymike
Then its not SOTF (Shift on the Fly). Sounds like your transfercase shifter linkage is in a bind. Have you tried shifting it with the truck in forward, reverse, coasting, neutral, etc? Sometimes you have to move the driveline around for the gears to un-mesh.
Old Nov 14, 2012 | 12:57 PM
mcmavv's Avatar
mcmavv
gonna try that next
is there anyway to lube up the linkage so i can avoid this happening again.
larryb346
Missouri Chapter
Sep 17, 2013 09:25 PM
NitrousAl
1997 - 2003 F150
Oct 1, 2005 09:35 AM
wezol5484
1997 - 2003 F150
Sep 19, 2004 09:46 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
