Shift Lever Lose
Old May 21, 2003 | 10:32 PM
snowinindiana's Avatar
snowinindiana
Shift Lever Lose
I have a 1990 Ford F150, THE STEERING COLUM SHIFT LEVER PIN HAS WALLARD OUT AT THE BOTTOM OF HOUSEING DO THEY MAKE A REPAIR KIT TO CORRECT THIS PROBLEM MAKES THE SHIFT LEVER LOSE.
Old May 21, 2003 | 10:54 PM
BlueOvalRage's Avatar
BlueOvalRage
Shift Lever Lose
I don't know the answer to your question, but you might get a better response over in the forum for your year truck. Good luck!
Old May 22, 2003 | 04:44 AM
Racerdave's Avatar
Racerdave
Shift Lever Lose
The pin that holds the shifter in the column? Just buy a new one.... Or go to a wrecking yard, or try posting the question in a forum topic like 1990 Ford's. You will get a better responce. Good luck.
