6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Looking at 6.4 maybe.
Old Nov 11, 2012 | 10:23 AM
txtruckin's Avatar
txtruckin
I have been kind of shopping around for an f450 dually truck, and the 6.4 is in abundance in my area. But I am pretty leary of them do to the fact that my dealership has them in the shop all the time because they self destruct. Do you simply delete the dpf, and that will keep the engine from roasting itself????????
Old Nov 11, 2012 | 11:12 AM
wp6529's Avatar
wp6529
The 6.4 does not typically "self destruct", in many cases it is aided in destructing by operator who do not understand the requirements of the new emissions controlled diesels and use them for the wrong type of service, neglect maintenance, etc. Properly operated and maintained the 6.4 and other emissions controlled diesels do just fine.
Now if you are looking at a used one, you have to be concerned about it's useage and maintenance prior to your purchase. Unlike pre-emissions diesels the post-emissions diesels can go bad very quickly if they are neglected or are used for all short trips.
The problem with assessing a used post-emissions diesel is that much of what you want to inspect is not readily visible. On the 6.4 you would ideally want to inspect the following:
- Lower HFCM fuel filter and housing for signs of gunk buildup, and to ensure the filters have been changed.
- Upper fuel filter, looking in the bottom of the housing for signs of rust spots or metal flakes both of which can mean expensive fuel system repairs.
- The water pump back housing for signs of cavitation damage.
- Coolant nitrite test to see if the coolant has been maintained properly.
- Used oil analysis on a sample with ~5k miles on it.
- Check for signs of leaks at the radiator hose connections and the radiator itself.
Since a used vehicle at a dealer has probably recieved a basic service with new oil and filters, some of the information you want will not be available at all.
Clearly the water pump housing can not be inspected in any reasonable fashion. The lower HFCM filter and housing can't be inspected without draining a quart plus of fuel and making a mess so it's not easily inspected.
The upper fuel filter can be inspected fairly easily with a flashlight, wrench and a container to rest the filter in when removed. This is one inspection you should absolutely do since a high pressure fuel pump and injectors is a good $8k repair.
The coolant nitrite test is another quick and easy test you can do, clip a test strip on the end of a long hemostat and just dunk it in the coolant degas tank, wait the 45 seconds and compare the color chart. Most dealers probably won't change the coolant on a used truck so it your nitrite test shows under 300ppm nitrite, reject the truck for neglected maintenance.
My standard maintenance recommendations for the 6.4:
If you have not owned one of the newer emissions controlled diesels previously (any brand), be aware that they are far more dependent on proper maintenance than earlier diesels.
Key 6.4 maintenance items:
* Oil changes every 5,000 miles, with quality oil (synthetic recommended), used oil analysis (Blackstone) for every change. Use only Motorcraft oil filters or the Racor (OEM) equivalent.
* Fuel filter changes every 10,000 miles. Use only Motorcraft FD4617 or the Racor (OEM) equivalent filters.
* Coolant nitrite testing at least every 15,000 miles. I recommend every 5,000 miles at the same time you do the oil change for simplicity, the test strips are inexpensive. Do not be confused by the test directions warning not to sample from an overflow tank, the 6.4 does not have an overflow tank it has a degas bottle. The degas bottle is part of the coolant loop with constant circulation so it is a valid testing point. I do not bother "taking a sample", I simply clip the test strip on the end of a long hemostat and dunk it in the degas bottle to test. If the test is below 800ppm and above 300ppm add two bottles of VC-8 additive. If below 300ppm the entire coolant system must be flushed with VC-9 cleaner, rinsed well and refilled with new coolant.
* Cooling system flush with VC-9 and refill with Ford Gold coolant every 60,000 miles, sooner if you have neglected testing and the nitrite is under 300ppm.
* Use a quality fuel conditioner such as the Ford PM-22a/23a conditioners at every fueling. They add lubricity to the fuel, something that ULSD is lacking in which helps protect the high pressure (up to 26,000 PSI) fuel pump. They also help to reduce soot production which results in less frequent DPF regens and less fuel dilution in the engine oil.
* Drain the HFCM water separator monthly. The fuel drained can be poured back into the tank carefully leaving behind any water at the bottom of the collection jar (normally very little). If the water separator drain does not flow well or at all, it may be clogged with either parafin blobs or with bacterial growth. In either case at a minimum the drain valve cover needs to be removed and the clog cleared. If the clog is significant the HFCM cover needs to be removed for full cleaning. If the clog is white and waxy it's parafin and not a significant issue. If the clog is brown or similar and more slimy it is bacterial growth and the fuel tank should be "shocked" with a biocide such as Power Service Bio-Kleen which should not be confused with their Diesel-Kleen.
* The truck should not be used for all short trips and stop and go traffic. The 6.4 and other emissions controlled diesels need regular longer periods at highway speeds to allow proper DPF regeneration and to get to proper operating temperature to help reduce fuel contamination in the engine oil.
* The latest PCM flash (11B23) does not provide continuous indication of when a DPF regen is taking place, it does however add much improved engine monitoring for developing issues. Over time you will get to recognize the subtle changes, but I recommend adding something like the ScanGauge II which will allow you to monitor the DPF temperature which is a clear indication that a regen is in progress when over ~600F.
* Avoid shutting the truck down with a regen in progress. If you have to, run the engine at high idle for a few minutes in park before shutting down to allow the turbos to cool down to normal temperatures before shutdown. If you are interrupting the regens you will see it in your Blackstone report, otherwise you should see very little fuel dilution, <1%.
You should also absolutely get the Ford ESP extended warranty, any repairs to the 6.4 are expensive and a single big repair can easily cover the cost of the ESP warranty. The coolant nitrite testing that many people overlook *is* in the owner's manual diesel supplement, so if you neglect it Ford can deny warranty coverage for resulting damage.
Other Super Duty maintenance items:
* Batteries - The batteries in these trucks are not the maintanence free / unmaintainable type, pop the caps to check and top up with distilled water periodically.
* Change transfer case fluid every 60,000 miles.
* Change rear differential fluid every 50,000 miles on DANA axles (F350 DRW and up).
* Change transmission fluid and filter every 60,000 miles on Torqshift transmissions (100k on manual transmissions). If you have the early Torqshift with the external filter the interval is much shorter.
Resources:
Coolant test strips - Buy the 4pk, not the bottle of 50, the strips have expiration dates and you'll only need <10 per year. Most dealer parts counters should have the test strips, NAPA has them, or order direct from Acustrip.
http://acustrip.com/CTS-3_Retail_Order_Form.pdf
Used oil testing - Blackstone Labs, get the pre-paid 6pk of test kits to save a few bucks. You don't need the TBN option:
Order Now
Ford ESP extended warrantys - You can buy them online from real dealers, or use the online price from a real dealer to negotiate a better price from your local dealer. You absolutely want the ESP, while the 6.4 is not problematic as some claim as long as you maintain it properly, nearly any repair is big $ and one good one will cover the ESP cost:
Ford Extended Warranty - Genuine Ford ESP
DPF, oil, coolant temp monitoring - ScangaugeII, you will need to program the X-gauge commands for the 6.4:
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
Ford Specific XGauges : Linear Logic : Home of the ScanGauge
Old Nov 11, 2012 | 11:38 AM
txtruckin's Avatar
txtruckin
I am looking at this for use as a hotshot truck, hauling cattle within about 150 miles of my hometown. This will take my V10`s place, so I have been looking at a either 6.4 or 6.7. Which do you think is better suited for what I am wanting to do? Will be mostly highway driving at 75 or 80. LOaded pretty heavy with a 40 ft tri axle gooseneck.
Old Nov 11, 2012 | 12:38 PM
wp6529's Avatar
wp6529
There are a few theories on this:
The first theory says do not buy a used truck of unknown history for business use. Down time costs you far more than the savings of used vs. new.
The other theory says that the 6.4 has a longer track record than the 6.7, the potential problem spots are known and if you are attentive to maintenance there is theoretically less risk due to less unknowns.
The third theory says that gas engines have come a long way and sticking with the V10 gas, which as far as I know is still availeable on the F450-550 chasis cabs you can put a hauler body on may be a safer bet until the diesel emissions stuff goes another generation or two and is more refined.
Old Nov 11, 2012 | 01:03 PM
RM2738's Avatar
RM2738
If you do decide on a used 6.4, get an Oasis report from your local Ford dealer. There's a chance the truck was maintained by Ford and the maintenance records will be listed. You'll also be able to see any repairs done by Ford.
Old Nov 11, 2012 | 02:13 PM
txtruckin's Avatar
txtruckin
I have really thought about just staying with the v10. It just has to work its *** off with some of our loads. I just thought a diesel might eliminate some of the stress on the drive train. It has never once left us in a bind. I do not really care about the loss in mpg`s, the difference between gas and diesel prices balances it out. I was mostly curious if I still would need to delete the dpf and other emmisions equip, if I wanted any longevity out of the truck. I usually keep my trucks a LONG time. I even still have one of those old 460`s haha. I fully plan on keeping these until they are 400+k on a diesel. My gas trucks I keep until they are at about 250-300k.
As far as buying used equip. I am a small business, that has always bought used equip. There is absolutely no way, I could afford a $60+k truck right now. Plus, I would rather let someone else take the hicky on depreciation. I always buy a truck with at least 25K on it, that way the biggest part of the depreciation is already gone.
Old Nov 11, 2012 | 02:56 PM
senix's Avatar
senix
6.4 F450 is the most capable compared to F450 6.7.
6.4 as a hwy motor..a motor that can work hard is good. City motor-bad.
I think you will find that the most of the bay is filled with city trucks or those with lack of maintance.
I would not hesitate in a minute to put 15K behind mine a goes cross-country right now...wait...I've done that a few times already.
Old Nov 11, 2012 | 10:13 PM
txtruckin's Avatar
txtruckin
Good to know. Am I correct in thinking that the 2008-2010 F450 is only available with 4.30`s like the current version??? Also, is that Dpf delete encouraged for the longevity issue?
Old Nov 12, 2012 | 05:05 AM
senix's Avatar
senix
4.30 or 4.88 were the gears available. Some put 3.73 in them but as far as I can recall they did not come factory that way.
If you fine one you like I would not delete right away. You may decide it is not a problem.
I still have mine as it does not bother me.
Old Nov 12, 2012 | 09:32 AM
wp6529's Avatar
wp6529
A key thing to keep in mind on the gas vs. diesel thing is that you need to order different axle ratios for each since the power band of a diesel engine is at lower RPM than a gas engine. You want the axle ratio to put the engine in it's power band at your normal driving speeds, thus the diesel might get 4.10 axles and the gas 4.56. Either way, the transmission and drivetrain is going to be identical on a F450 regardless of the engine selection, so there isn't any more or less stress on it.
Old Nov 14, 2012 | 09:56 PM
BigBlueOx's Avatar
BigBlueOx
Subscribed
Old Nov 14, 2012 | 10:31 PM
txtruckin's Avatar
txtruckin
I appreciate all the information. Based on what I have read over the past several days it seems like the 6.7 will be better suited. I`m basing this on the fact that there will be times that this truck will have to idle over night. Everything that I have read also leaves me to believe that the 6.7 is just all around a more reliable engine. when hauling livestock, reliability is extremely important. Don`t get me wrong, I would be pissed if my truck left me on the side of the road regardless of which engine it has. It just seems the 6.7 is less likely to have this happen. Almost reliable as the trusty gasser, with more power...........
Old Nov 15, 2012 | 06:49 AM
RM2738's Avatar
RM2738
Idling for long periods isn't good for any of the newer common rail diesels. If you must idle, the High Engine Mod is strongly suggested. There are people that let their 6.4 idle regularly and don't have any problems.
Old Nov 15, 2012 | 08:40 AM
wp6529's Avatar
wp6529
^ This. If you need to idle any of the new emissions controlled diesels for extended periods or use for PTO operations you need to do parked regens for the DPF. There is a Ford recommended box available to do this on a 6.4, I'm not sure on others.
Given that extended idling of diesels is illegal in a great many areas and most commercial trucks have gone to either certified clean idle engines or APUs, I'd look at other options rather than idling. Again, sticking with the V10 gas may well be the best option.
Old Nov 15, 2012 | 09:51 AM
RM2738's Avatar
RM2738
