Bronco II Ford Bronco II
Jackin' It Up!!!!!
Old May 21, 2003 | 05:46 PM
ShadowBronco2's Avatar
ShadowBronco2
Question Jackin' It Up!!!!!
I want to put a lift on my 1985 B2 but im havin trouble picking what kind of lift to put on it. I'm going to be putting 31 inch tires on 8 inch rims. I'm thinking body lift because it's cheap, but im also thinking of a suspension lift because it seems to be the right way to go. Price isn't really a concern because I'm replacing my shocks all the way around also, so why not go the rest of the way. Any suggestions as to the best way to go?
Old May 22, 2003 | 11:15 AM
rebocardo's Avatar
rebocardo
Jackin' It Up!!!!!
A 2 inch body lift will only be good enough for about 30s if you really go off-road. A 3 inch body lift causes too many problems, especially if you have an automatic. I went with teh 2" from James Duff and it was okay. I would have wished the bushings were wider.
A 3 inch James Duff suspension lift should be good for 31s.
Old May 29, 2003 | 07:52 AM
SplashMan's Avatar
SplashMan
Jackin' It Up!!!!!
James Duff or SkyJacker seem to be the best lifts out there for B2s... one of my B2s has the Skyjacker 6" class II (comes with new radius arms and new rear leafs) and I can comfortably run 33x12.5s.
Old Jun 4, 2003 | 09:37 PM
Bronco 1169's Avatar
Bronco 1169
Jackin' It Up!!!!!
I got a 6 in on my and it's nice. i like it just fine it's high but no too high and it look good too.
Old Jun 10, 2003 | 10:32 PM
tylerdurden's Avatar
tylerdurden
Jackin' It Up!!!!!
i have an 86 bronco 2 and want to get a small lift without much hassle.....bigger tires too ...but i want to ride on the highway without much resistance from the tires anyone have suggestions?? on lift height...i was thinkin 2" body...and tires 30??
