Porting Question
Old May 21, 2003 | 05:06 PM
gaspoweredsales28's Avatar
gaspoweredsales28
Question Porting Question
I have a pair of D2TEAA heads off my '75 390, and on the exhaust side there is a large hump on the floor of the exhaust port that I think would impede exhaust flow. Has anyone tried to remove this, and what kind of trouble or issues have come up? Thank you!
Old May 22, 2003 | 05:25 AM
karljay's Avatar
karljay
Porting Question
The hump on the floor (closest to the chamber) won't make any real difference in flow. You gain much more by working on the roof (it should have a hump in it) and the bowl area and then unshrouding the valves.
I don't know who did the flow tests on this but it was some time ago. I guess the roof is concidered the fast side and that's where the gains are made.
Old May 22, 2003 | 08:08 AM
gaspoweredsales28
Wink Porting Question
This confirmed my suspicions......flow along the port floor is not as great as it is along the roof, just like a Mopar.
Old May 23, 2003 | 04:28 AM
Ratsmoker's Avatar
Ratsmoker
Porting Question
You can't take that hump all the way out anyway. There isn't enough meat. I butchered a set of D2 heads from the scrapyard on purpose to see where the limits are and they have a good bit of meat, just not in that spot.
Old May 23, 2003 | 02:28 PM
fordification's Avatar
fordification
Porting Question
I'm pretty sure thats an EGR bump, and it can't be removed. He are the rules of porting that I've came across. Exhaust ports can be polished but with little gain. The bowl where the valves sit in can be ground. Where the machining for the valve ends and the port begins should be radiused. This applies for intake and exhaust. The intake port should be left unpolished. The rough surface contributes to atomization. Any casting flaws should be removed. Enlarging port dimension should be matched with intake/headers to keep a consistent flow.
