Broken wire in door jamb
98expy
When you open the front pass door the dome light only triggers when the door is already open half way, pretty sure it's a broken wire.
I peeled back the rubber grommet the wires pass through in between the door and didn't see any connectors I could disconnect to remove the rubber to repair the wire.
My question is,I don't want to cut the rubber so what's the best way to get to the broken wire?I really don't want to remove the door.
Flyview
07-09-2017 08:35 PM
