Wonderful work Rust Removal
Old Nov 8, 2012 | 10:36 PM
Super Econoline's Avatar
Super Econoline
Ultra One Degreaser really WORK removal rust y should try do for frames or Axle or body work?
Ultra One Degreaser and Safest Rust Remover
Old Nov 8, 2012 | 10:40 PM
Skip1970's Avatar
Skip1970
where you get that ultra one at?
Old Nov 8, 2012 | 10:51 PM
Super Econoline
Old Nov 8, 2012 | 10:58 PM
kevin316's Avatar
kevin316
Very cool stuff. I wonder what you would need to prepare for paint after using it?
Old Nov 8, 2012 | 11:02 PM
Skip1970's Avatar
Skip1970
thats what muratic acid does when you put rusty steel in it too. is that whats in thiis stuff?
Old Nov 9, 2012 | 12:07 AM
LITTLE BLACK TRUCK's Avatar
LITTLE BLACK TRUCK
Molasses and vinegar work well too. But be warned if you use vinegar keep an eye on it cause its strong stuff! When I pick up old rusty tools I soak em in vinegar for about 5 hours and then in molasses for a week. they comee out like brand new.
Old Nov 9, 2012 | 10:42 AM
HIO Silver's Avatar
HIO Silver
Originally Posted by LITTLE BLACK TRUCK
Molasses and vinegar work well too. But be warned if you use vinegar keep an eye on it cause its strong stuff! When I pick up old rusty tools I soak em in vinegar for about 5 hours and then in molasses for a week. they come out like brand new.
That may work but this works better: Electrolysis - Rust Removal
I set up 30-gallon system using scrap steel bars, a $6 box of soda, and my battery charger... plus it's usually done overnight.. I've rescued calipers, master cylinders, brackets, hardware, battery trays, tools, etc...It's super cheap too.. that store-bought stuff can get really expensive. During research, I found a thread where a guy built a plywood pool to de-rust an entire frame!
Here are before and after pics of my brake calipers. Absolutely no rust before I shot them with high temp caliper paint:
Old Nov 9, 2012 | 11:56 AM
Skip1970's Avatar
Skip1970
u just spraypainted them!
Old Nov 9, 2012 | 01:25 PM
HIO Silver's Avatar
HIO Silver
Wrong. Read the article ya noodle..... Here are pics of my crank pulley:
Before:
After. The dark areas is where the rust used to be.:
Old Nov 9, 2012 | 02:43 PM
Skip1970's Avatar
Skip1970
i can clearly see the spray paint pattern on the cardboard. i dont know who you think your fooling.
Old Nov 9, 2012 | 02:46 PM
gpence's Avatar
gpence
Who cares of he did spray his parts
Old Nov 9, 2012 | 02:54 PM
73FOMO's Avatar
73FOMO
He has two pics....one derusted (top pic) and then the other after he spray painted the derusted parts (bottom pic). I don't think he is trying to fool anyone.
Old Nov 9, 2012 | 03:18 PM
KingBigJoe's Avatar
KingBigJoe
As an experiment I put four rusty screws from my truck (when I removed the rear taillight bezels from Rustoleum's bed [that I sold later]) in a plastic bowl with vinegar for one week (checking it once a day) just to see if it was indeed possible that it was a rust remover. It worked so well that the vinegar turned black & it was hard to find the screws due to that (Don't worry I didn't lose the screws [they went with the bezels when I sold them]). I recommend this method of rust removal if your cheap.
Last edited by KingBigJoe; Nov 9, 2012 at 03:20 PM. Reason: I fixed a minor error & fix a letter in a word.
Old Nov 9, 2012 | 03:36 PM
KingBigJoe's Avatar
KingBigJoe
b-uno, HIO did derust the parts with electrolysis. Read his build thread for his 1970 F100. There is more pictures there as proof.
Old Nov 9, 2012 | 03:38 PM
Skip1970's Avatar
Skip1970
geez you guys dont pick up on humo too well.. i was pullin his chain.
