Before you buy a compressor
It's a 220 unit and it really was 183 at start up and dropped to 30.3 very quickly so that's why things are not melting or popping.
Bottom line is you definitely want to know start up amps before you make your purchase. I would have never had guessed it would be so high.
Surge: 220 x 183 = 40,260 watts
Running at that wattage for one hour would use up 40.260 kwh. But..
40.260 / 60 / 60 / 10 = 0.001118333 kwh per surge
Your compressor uses 220v at 30.3 during normal operation.
220 x 30.3 = 6,666.
Run that for an hour, and you've used up 6.666 kwh.
6.666 / 60 / 60 = 0.001851666 kwh per second
Hmmmmmmm,
0.001118333 kwh
0.001851666 kwh
Running your compressor for 1 second uses more electricity than the surge uses.
Sure, your lights may dim for a fraction of a second, but don't worry, you won't see a dent on your electric bill...at least not as a result of the surge.
Hard Start Kit 1 115 288V 1 2 10HP New 500 Boost 4000 to 120 000 BTU | eBay
