Sponsored by: Auxito
Disc brake pad thickness ?
Old May 21, 2003 | 02:04 PM
pilot10's Avatar
pilot10
I have an 01 F-150 w/ the 5.4, 4x4 in the Lariat version(4 wheel disc brake) with 44,000 miles.
I've had the tires rotated a couple of times and every time the wheels are off I take a look at the pad thickness. It does not appear to change. I've double checked a couple times to make sure I was looking at the pad. The pads appear to be about 3/8"-1/2" thick which is as thick if not thicker than any of the other disc brake pads I've looked at. Granted all the other vehicles were either cars or small trucks so I would expect the pads to be a bit thinner. On my last truck, a '94 ranger, I was getting only 25-30,000 miles out of the front brakes. The stock rotors on that truck were pretty weak(thin) and one servicing(turning) would reduce the the rotors to the minimum usable thickness.
From what I've read here some people are getting 80,000+ miles out of their brakes. So am I correct in believing I have quite a bit of pad life left?
Thanks
Tim
Old May 22, 2003 | 12:25 AM
Racerguy's Avatar
Racerguy
New pads are almost 7/16" thick so it does seem like you have lots left. The pads on the newer trucks last a long time under normal use.
Keep checking them when you have the wheels off. When they get down to about half of what they are now you should probably
remove the pads and look to see how close the rivets are to the pad surface to give you a better idea of when to replace them.
Old May 22, 2003 | 08:21 AM
pilot10's Avatar
pilot10
Thanks. I was concerned because I just couldn't believe I was getting that kind of long lasting wear out of the brakes. I guess I'm not used to(yet) the almost non existent servicing this truck needs. My last full size pick-up, an '59 F100 w/ a 292 V8, required almost constant tinkering.
Tim
