IAC question
Old Nov 7, 2012 | 07:05 PM
MikeB 88's Avatar
MikeB 88
IAC question
I've replaced the IAC and DPFE on my ranger a couple times due to the racing idle. Vacuum lines have also been replaced. Question is, Can the electrical connector build up a "static build-up" and prevent it from working?
I ask because every couple months or so, my truck's idle will start racing. I'll unplug the IAC when I get home from work, and plug it back in next time I drive the truck. It will then idle just fine for another couple months.
Old Nov 10, 2012 | 06:51 PM
pawpaw's Avatar
pawpaw
Static charge.....not likely, but did you replace the IAC with an aftermarket, or Motorcraft part????
Old Nov 10, 2012 | 07:27 PM
MikeB 88's Avatar
MikeB 88
Aftermarket, BWD from Advance Auto Parts.
Old Nov 10, 2012 | 07:53 PM
pawpaw's Avatar
pawpaw
OK thats the brand I'm using & I've had the engine speed run away a couple of times since, just like, but not nearly as often as the OEM IAC was doing before it was replaced.
Strangely it most often happens after coming to a stop after climbing a grade, usually when towing. I just shift to "N" & let the rev limiter deal with the runaway rpm. Once the rev limiter kicks in, the RPM quickly comes under control & drops back to normal. Sometimes it'll take a year or so for it to act out again, so I've come to suspect a computer program problem, or maybe something to do with the speed sensor signal processing, don't really know, just rambling on, because the problem although better, the repacement IAC hasn't totally fixed the problem.
Old Nov 12, 2012 | 07:59 AM
MikeB 88's Avatar
MikeB 88
Thanks for the input. I will keep thinking on this for a while. Maybe by unplugging the IAC, it resets the computer for a while??
Old Nov 12, 2012 | 09:06 AM
pawpaw's Avatar
pawpaw
After a runaway rpm event, do you have a CEL lit, or have you had the computer scanned for set, or pending codes, as they could offer up good trouble shooting clues.
Were the replaced IAC's dirty/oily/carboned up???? If so, suspect something like a mucked up PCV valve, or kinked, or cracked hose to it.
After a battery disconnect, that wipes the computers KAM, in which resides the cold & warm idle strategy, have you done the cold & warm idle relearn proceedure here???
Ford Truck Enthusiasts Forums - View Single Post - high idle problem
Old Nov 12, 2012 | 10:10 AM
Hank85713's Avatar
Hank85713
I had a problem and after a couple of hours with all the tech manuals and computer scopes etc, it was determined that the wire had a short somewhere in the bundle that it is routed through. Never did figure it out so now just run it disconnected, I did run the idle nut out a little. Still hold 750 rpm with the ac on so its good. Have had it like this for almost 6 years no problems. Does not over rev with the ac off but hold around 8-900 rpm. Makes life easier without having to worry about the engine speeding up at stops.
Old Nov 12, 2012 | 07:00 PM
MikeB 88's Avatar
MikeB 88
No CEL light and I haven't taken it to see if there are any codes. Next time it does it, I'll do that though.
IAC was first replaced due to the high idle. PCV was replaced about 4 years ago due to a code for it, but the hose looked good, so it stayed. No cracks, or soft spots in it.
Battery wasn't disconnected, just the IAC. Truck being a 5 speed manual, I didn't think the idle relearn procedure would affect me.
WB4IUY
Escape & Escape Hybrid
Jun 2, 2014 08:04 AM
musicars
Dec 1, 2013 05:50 PM
imsorope
Oct 5, 2010 06:31 PM
nat13_3
Jul 22, 2009 08:08 PM
JEV
17
Jun 9, 2005 08:28 PM
