1978 - 1996 Big Bronco
Bronco Rear Window Problem
Old May 20, 2003 | 10:38 PM
Castoff52's Avatar
Castoff52
First time, looking for help....
1996 Bronco tailgate window: This subject has been posted a number of times, but I can't find what I need. With the window stuck in the down position, how do I access the "safety switch", which I believe is the problem... The window works fine unless lowered all the way, so both the dash and key switch seem ok, and the motor is ok. Can I get to the safety switch without taking the glass out.
Old May 20, 2003 | 10:55 PM
Jim242002's Avatar
Jim242002
Put this post in the Big Bronco (1978 - 1996) section,you will get your answer,
can't post tech stuff in the garage and workshops threads
Old May 21, 2003 | 05:54 PM
ftrucktough's Avatar
ftrucktough
isn't that what this is?
Old May 21, 2003 | 06:09 PM
rogue69's Avatar
rogue69
Yes it is.
Old May 24, 2003 | 09:05 PM
Wakeboarder141's Avatar
Wakeboarder141
You just need to remove the inner access panel inside the Bronco. It is about 8 screws to remove that inner panel of the tailgate. The wiring harness for the safety switch is on that side of the glass so that isn't a problem.
Old May 24, 2003 | 09:25 PM
steve83's Avatar
steve83
Look here: http://www.webphotos.com/list_photos...&smi=2&a=73922
