Block Heater
Old 11-02-2012, 06:35 PM
Csymons's Avatar
Csymons
Csymons is offline
Block Heater
How can you tell for sure that your block heater is working properly?
Old 11-02-2012, 07:19 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
i can hear a "humming" noise coming from the area of the block heater when i plug it in and i am very quite and listen. easiest way it to plug it in for an hour or so and then feel the passenger side head/valve cover. if the heater is working then the head/valve cover will be warm.
Old 11-02-2012, 07:20 PM
Csymons's Avatar
Csymons
Csymons is offline
Thank you I will try that
Old 11-02-2012, 07:26 PM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
Like Eric said, I can hear a faint 'sizzle' after it's been plugged in for a bit. I also see a spark at the plug in when it makes contact with the extension cord....
Old 11-03-2012, 12:24 AM
jayro88's Avatar
jayro88
jayro88 is offline
I just had to troubleshoot mine. I use a ohm meter to check for continuity. Your resistance will vary depending on the wattage of your heater, but they all should have continuity. I check mine at the plug and got nothing. I then unplugged the cord from the heater and ohm'd the heater. Had continuity. Pulled the cord and found a bad spot. Repaired it and now I am good to go.
Old 11-09-2012, 01:47 AM
Csymons's Avatar
Csymons
Csymons is offline
No warmth guess I will have to check the cord tomorrow.
Mcfarlane11
02-28-2014 12:32 PM
ken 01
01-04-2011 01:58 PM
DieselBeast01
17
11-18-2008 11:48 PM
shendren
01-13-2004 08:48 PM
FarmLaw
1997-2006 Expedition & Navigator
01-10-2004 02:27 PM
Quick Reply: Block Heater
