96 Ford F150 dies while idling then won't start for a while
#31
#32
I'd be inclined to replace the distributor at this point. Me being me, I'd swap in my spare which is a "known good" one I grabbed at the junkyard.
#33
Dielectric grease is not a heat transfer grease.
#34
If you need electrical conductive grease, one of the metal infused (silver, aluminum, etc. thermal greases) will be required. Perhaps even anti-seize would work since it is electrically conductive.
#35
#36
#37
#38
What we are talking about is the heat transfer between two metal parts to keep the ICM cool on a fuel injection engine. One of the parts is finned with a flat surface that the ICM screws to. The heat transfer grease (white thermal compound) is used between these two surfaces.
#39
i also had this problem with my 92 with the 4.9 what mine turned out to be was a weak ignition module, the great part is the top of the line ignition modules are 50 dollars max, my mechanic said this was a common problem with them and only charged me 50 dollars for labor what happens is as you drive the electrical current warms up the wire and then for some reason it looses conductivity and the motor dies, this happened to me as i was doing 80 down the interstate, all i have to say is when you lose all power accessories at 80 your drive gets wayyyyyy more interesting
#40
Not to hi-jack too far off course, but I noticed the earlier comment about this application requiring the black TFI rather than the gray. Is that correct? If so, what year was the change-over made? I know the '92/3 trucks at a minimum used the gray one. I was under the impression the gray one was used through to '96 but I'll gladly be corrected if that's not right.
#42
#43
Regardless, the symptoms described here are not really consistent with an ignition switch failure. They ARE consistent with a component failure, such as the TFI or PIP (inside the distributor).
#44
The last year that ford used the push-start gray Ignition Control module in a truck was 1993.
The 1994 and newer truck used the CCD Black Ignition Control Module (ICM).
You can plug the gray one in a 1994 and newer truck but it will not start or run as well. It will also set a code in the computer memory that you are missing the IDM information.
#45
If you have to take the steering wheel off it was not the Ignition Switch. Could have been the Ignition tumbler, the thing you put the key in and turn. But I think it can also be changed out without pulling the steering wheel.
The Ignition switch is located under the dash and mounted on top of the steering column.
Maybe the clockspring but that should not have killed the engine.
