Gas Tank Problem
Old May 20, 2003 | 09:11 PM
junior14's Avatar
junior14
Question Gas Tank Problem
I am hoping that someone out there can help me to solve this problem. I have a 89 F350 Dually with a 351 windsor (gasoline). It has two gas tanks and when I run on the rear tank the truck runs fine. However, when I switch over to the front tank while driving the engine runs for about 30 seconds then it begins to chug and there is a popping noise coming from the engine compartment before it dies. If i switch back over to the rear tank the truck runs fine. The truck will idle in the drive way on either tank with no problem. Any input would be greatly appreciated.
Old May 20, 2003 | 10:20 PM
CrazyFordMan's Avatar
CrazyFordMan
Gas Tank Problem
get the fuel pressure checked when running off the front tank your pump is proberly getting weak. mine did this and no one could figure it out then i got my fuel pressure checked and it was opnly putting out like 5 psi
Old May 20, 2003 | 11:16 PM
steve83's Avatar
steve83
Gas Tank Problem
The '84-90 pump isn't exactly like this, and pickup tanks are smaller than Bronco tanks, but that should give you an idea of what it takes to change the pump. Some pickup owners pull the bed for access, but obviously, that's not an option on a Bronco.
