93 f150 short bed diy lift
hey im still new to this page but ive had a 93 f150 for bout 4 years now its my pride and joy and i dont plan on ever getting rid of it but i wanted to make it look a tad bigger i wanted to try to do a 2"-4" lift on it but im not even sure where to start any help would be great ill try to post some pictures of it.
Thanks
Thanks
The body lift blocks are a high strength reinforced Nylon material. They are cylinder shaped. I have a 3" body lift on my truck.
Put it this way: If you get a body lift, you don't have to get an alignment afterwards and you can then fit larger tires. The one downside is that it does not increase frame to ground clearance. Also you have to use supplied brackets to lift the 3" gap that will be created above the front bumper. The rear bumper will also need to be raised 3" by drilling new holes in the frame to relocate it.
Suspension lift will get your frame up away from the ground, along with the rest of the body. The only way to increase axle to ground clearance is larger tires.
You can get a full suspension lift kit with drop brackets and everything needed. Or else you could get 2" coil spacers to lift the front end and something like 2" lift blocks to put in the back under the leaf springs to lift the rear of the truck.
dandude2103
11-13-2003 08:21 PM
Tectron1
05-19-2003 04:09 PM
