Sponsored by: Kumho
Daystar spacers
Old May 20, 2003 | 07:45 PM
sandman3510's Avatar
sandman3510
Daystar spacers
Anyone have any experience with the polyurethane Daystar (or other) coil spring spacers? I'm just looking for a small amount (about 2") of lift without sacrificing any ride quality. My current coil springs are still good, so I was thinking about installing these spacers.
Any thoughts?
Thanks!
Pat
Old May 20, 2003 | 08:11 PM
RBrendel's Avatar
RBrendel
Daystar spacers
i have the 2 inch daystar spacers. all i can say is that they are great. gave me a full 2 inches with no settle. i beat my truck up pretty damn hard and these things have held up perfectly. id go with them before the skyjacker leveling springs (i have those too) good luck
Old May 20, 2003 | 08:17 PM
retired2001's Avatar
retired2001
Daystar spacers
Same question I had! I have a 2002 2wd S'crew and only want to "level it". Do you have to "re-align" the front end? Thanks, for the information!
Old May 25, 2003 | 04:39 AM
brokebronco's Avatar
brokebronco
Daystar spacers
What year models do the spacers come in? I have an 84 Bronco that I'd like to level. Also, does anyone have a web address where I can get some info?
Thanks
Chris
Old May 25, 2003 | 09:41 AM
WhëëlMå1's Avatar
WhëëlMå1
Daystar spacers
Yes, AFAIK you will have to realign. I know I did when I installed my leveling kit (springs, not poly). Are you all sure you want them? You normally get what you pay for. They are prone to deterioration, and Im sure you dont want to find out at 55mph when they finally give out. Just an idea.
Rich
Old May 25, 2003 | 08:17 PM
brokebronco
Daystar spacers
Thanks WheelMA1, The original rubber spacers are totally shot so I thought to get a little extra height to clear the 33's at full stuff.
I have the front coils out of an 86 2WD F250 HD. Cheap lift and I like the ride firmed up that way. I also put the rear leafs on but hat to remove the overload leaf. TOO stiff.
Old May 25, 2003 | 08:48 PM
retired2001
Daystar spacers
Thanks for the info'! Do you know if these are Polyurethane or rubber? If urethane, they should be pretty durable. If rubber they will probably go away pretty quickly. Thanks, again!
Old May 25, 2003 | 09:14 PM
WhëëlMå1's Avatar
WhëëlMå1
Daystar spacers
The ad says that they are in fact polyurethane. I hope they work out for your if you go down that road. brokebronco, did you have to fab anything up for that spring swap? How much taller are those than the stock bronco springs.
Rich
Old May 27, 2003 | 10:31 PM
brokebronco
Daystar spacers
When I originally changed the springs, they were so wore out and s-wrapped that I got 7'' in the rear and around three in the front. Figuring the amount of sag in I probablly got aroung 4'' in the back and oround 2.5 to 3 in the front. As for mods, there were none, direct bolt up. The only real mods on the rear end were the brake lines when I installed the 10.25.
As long as you don't mind a stiffer ride, it is a good swap. Seeing as I like to use the Bronco as parts hauler and tow vehicle it was good for me.
Regulator1988
Jul 11, 2012 02:33 PM
65F1005.8
Apr 13, 2011 08:23 PM
kslhol
Apr 11, 2008 11:29 PM
rubberducky
1983 - 2012 Ranger & B-Series
Oct 25, 2005 10:32 PM
john_rey
1997 - 2003 F150
Jan 24, 2004 10:33 PM
