6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
HELP! constant black clowd @ wot...
Old Oct 31, 2012 | 02:07 PM
fordtruggy's Avatar
fordtruggy
I think my baby may be sick. Always had a big black puff during a hard take off but now recently I've got a huge black cloud the entire time its floored. Also, its falling short of 40 psi where it usually tops out at.
S&B cai.
Mini maxx
HD300 Hot.
S2M.
4" all the way.
DPF-CAT deleted
EGR shut off.
LBF set on 5. coolant defuel at 170, 220. EGR at 1550. Boost at 42.
Old Oct 31, 2012 | 04:30 PM
xpl0sive's Avatar
xpl0sive
have you tried lowering your LBF?
Old Oct 31, 2012 | 05:56 PM
fordtruggy's Avatar
fordtruggy
No I haven't. It's more sluggish off the line now also. Been running this tune for a while now with no issues. Not sure what could have changed all of the sudden..
Old Oct 31, 2012 | 09:26 PM
RM2738's Avatar
RM2738
You know... I've kind of felt like mine doesn't have quite as much "get up and go" as she used to. I'm running almost identical except my defuels are a little more conservative. How's your fluids? Did you get the latest H&S update? I'm gonna dig under the hood this weekend and see if I might have a loose or torn boot somewhere. CAC, downpipe or something. Didn't think too much of it, but then you posted this...
Any OA's? Maintenance intervals?
Old Oct 31, 2012 | 10:55 PM
fordtruggy's Avatar
fordtruggy
I did re install the tuning again, didn't change anything. Not fixed. I will say it was shortly after my last service that this problem started. Changed both fuel filters. The one under the truck, drivers frame rail was shot. Couldn't have been working at all. Service department must have missed it the past few times.. maybe I need to check my air piping for a torn boot also. Must be getting plenty of fuel due to the smoke but the boost just isn't coming up..
Old Nov 1, 2012 | 02:24 PM
xpl0sive's Avatar
xpl0sive
it could be something to do with the winter blend fuel... maybe thats just how your truck runs on it... have you tried adding Cetane booster? I bought some from Ford and truck seems to run smoother and builds boost better
Old Nov 1, 2012 | 05:13 PM
slowmans's Avatar
slowmans
Nothing to do with winter fuel, it doesn't make a truck run much different if at all?????
I would be looking for a blown boot or maybe a severly clogged air filter?
Old Nov 1, 2012 | 11:09 PM
fordtruggy's Avatar
fordtruggy
A blown boot would make perfect sense and hopefully an easy find, and fix. I'm going to start with that.
Old Nov 1, 2012 | 11:10 PM
fordtruggy's Avatar
fordtruggy
I thought about the air filter, but wouldn't it trip the filter sensor if it was plugged?
Old Nov 2, 2012 | 08:10 PM
fordtruggy's Avatar
fordtruggy
Problem fixed. Had to be a leaky boot. Never did "see" anything wrong but I loosened all of them up, cleaned them and re tightened them all. Must have been leaking past a clamp.
Old Nov 2, 2012 | 08:44 PM
RM2738's Avatar
RM2738
Good to know. I was looking today while fueling and I've got a good amount of a black oily substance on the cold side CAC boot going into the CAC. I'm wondering if that's leaking somewhat. I'll remove and clean it up tomorrow. Other boots all checked out ok from a basic visual inspection.
Old Nov 3, 2012 | 12:24 AM
parkland's Avatar
parkland
Mine leak at every boot, both sides.
Ford said it was normal, and leave it alone.
Old Nov 3, 2012 | 06:55 AM
RM2738's Avatar
RM2738
Ford also claims that 5% fuel dilution is normal, they also told me that my "death wobble" is because my tires are bad....
Old Nov 3, 2012 | 11:46 AM
jasfaa's Avatar
jasfaa
Not normal. Wow that's bad advice
Old Nov 3, 2012 | 11:50 AM
parkland's Avatar
parkland
I know, I just left it alone cause mine makes normal boost.
Eventually I guess something will need to be done.
