I had my front end aligned in my 93 f150.73,000 miles. They renmoved the caster camber bushings and used these universal bushings to correct the alignment. It drives great and now the front tires dont lean out at the bottom. Has anyone else had these universal bushings installed? And what do you think about them. Thanks in advance.
Should be ok, the stock camber adjustment nuts only adjust 1 degree pos or neg, they have 2 and i think 3 degree ones too.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
