getting a new engine.....
Old Oct 29, 2012 | 06:57 PM
DIYMechanic's Avatar
DIYMechanic
Not if you have the Cali PCM.
On the other hand if you get custom tunes for the Cali injectors you will gain a little more than a truck with stock AA (90cc single shot) would. The cali injectors are closer to the potential of the 140cc injectors in the SD (99+) 7.3. Plus since they are split shots they will run a little smoother. They do, on the other hand take a bit more HP oil than the AA's but the cali trucks seem to do pretty well.
Old Oct 29, 2012 | 06:59 PM
427 fordman's Avatar
427 fordman
Originally Posted by matowns21
Do I have to do anything to utilize the potential hp that the oversized injectors can make over standard?
Just run the cali pcm. Like Jim said above, wiring is a little different I think. Finding a cali pcm isn't that easy iirc. If it were mine, I'd stay away from the cali version, jmo.
Old Oct 29, 2012 | 07:02 PM
matowns21's Avatar
matowns21
How much do Calif injectors run.... Used
Old Oct 29, 2012 | 07:08 PM
DIYMechanic
Should be about the same as regular AA code injectors. The only issue is that there aren't a lot of them out there. I think they're AB code injectors. Someone correct me if I am wrong. (I know they're AB or AC code, and I think the AC's are the E99 injectors) Jim Rose would know for sure. Send him an email.
Old Oct 29, 2012 | 07:12 PM
427 fordman
They are AB injectors, same as the E99
Old Oct 29, 2012 | 07:15 PM
strokin'_tatsch's Avatar
strokin'_tatsch
AB codes were 120cc split shots found in OBS cali trucks and Early '99 SDs. Late 99 went to the AD 140cc split shots. AC codes are 160cc single shots with the same nozzles as our stock injectors, so basically they are a factory built stage 1 injector. The AC code injectors were in the T444E in dump truck and school bus applications IIRC.
The AB codes can be used in your truck if you get a chip burned for the ABs. Your stock HPOP probably won't be able to keep up though since split shots use quite a bit more oil.
Personally I'd sell the ABs and either use stock single shots or get some upgraded single shots. Split shots are a PITA..
Old Oct 29, 2012 | 07:28 PM
DIYMechanic
Thanks for clearing me up on that.
Old Oct 29, 2012 | 11:55 PM
oldbird1965's Avatar
oldbird1965
hang on, besides that you should be good. I agree with the above, if you can swing it cost wise, don't sell anything until you get it figured out. Any idea of what happened to the rings?
Old Oct 30, 2012 | 06:53 AM
matowns21's Avatar
matowns21
Glenn, I was told these trucks are notorious for breaking rings in the two back cylinders. I had one mechanic say due to the cooling system has to pass through front to rear and by the time it gets back there its not really cooling so it puts stress on that cylinder. I talked to another mechanic that said because of the injectors either spraying too much fuel or not enough fuel.... I'm not sure really. Honestly your guess is probably better than mine. I bought this truck from a family member a couple years ago and it had set for nearly 4 years without anyone driving it. When I got it home the fuel bowl was gelled the air filter was one big dirt dobbers nest and the oil was low. I changed and cleaned all that then took it to Ford because it smoked really bad. They replaced 4 injectors and then the smoking got worst. With help here I narrowed the smoke to the number 8 cylinder. Pulled the head and really didnt like what I saw...
Old Oct 30, 2012 | 10:23 AM
oldbird1965
Man that's to bad. If your getting another engine the #8 cylinder must be to bad of shape to be bored out. I would like to find a motor to rebuild before mine gives up the ghost.
Old Oct 30, 2012 | 10:33 AM
matowns21's Avatar
matowns21
I actually found an engine with 150k on it as cheap as I can rebuild it and the used has a warranty... If I build it no warranty... I am pretty confident my engine can be built but i lack the knowledge and time.. but more knowledge than time....... What is the ghost?
Old Oct 30, 2012 | 12:24 PM
oldbird1965
Oh, just a saying that my motor will be dead if I keep running it the way I am.
Old Oct 30, 2012 | 12:58 PM
  #28
strokin'_tatsch
To my knowledge, these engines are NOT notorious for breaking rings. Cummins engines do have a problem with the back cylinders running hotter b/c the reason above, but these engines don't have any cooling system issues like that.
I would bet that the piston cooling nozzle for the #8 cylinder got loose or completely came out and wasn't spraying oil up to the piston before saying that the coolant caused any issues..
Old Oct 30, 2012 | 02:19 PM
  #29
matowns21's Avatar
matowns21
Travis, you may be correct. This is my first diesel so my knowledge is very limited I can only say what I have been told by other people... Everyone has some type of justification but with my little knowledge I can't call BS on them.
Old Oct 30, 2012 | 05:25 PM
  #30
strokin'_tatsch
I hear you. We've all been there. When you pull the engine out to swap, pull the oil pan off the bad engine and you will see the piston cooling jets at the bottom of the cylinders, aimed up at the pistons. Those jets spray oil up to the pistons to keep them cool and lubed. If the hold down bolt for one of those jets backs out and the jet comes off, it's all over for that piston. Look and see if the one for the number 8 piston is missing or loose on your engine. That's why a lot of people will weld the jets in place when they build these engines. It's not a common problem, but it CAN happen.
